Question about Video Game Consoles & Games
I cannot connect to my Linksys wireless router.
  • JWedel91 Jul 23, 2008
    I've done that. (I am trying to connect to my Wii) I thought I had that in my problem description, but I don't see it. It just keeps telling me that it can't find the connection. I even tried changing the channel or whatever from 6 to 1 or 11.
    Console starts out at all zeros.
    I can manullay enter whatever I want.
  • 137 Answers
Make sure that you are using the proper encryption type for the connection. Your router most likely is capable of handling WEP, which is what your adapter is more than likely set to use. Log onto your Linksys router by inputting the IP address into the address bar and then check the wireless security tab on the router interface
If you don't know the ip address, open a command prompt window and type ipconfig at the flashing cursor. the default gateway would be the address of the router.
Posted on Jul 22, 2008
  • nsindian
    nsindian Jul 23, 2008
    What IP address does the console have now? Or are you able to check?
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I get limeted access to internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router's SSID or the wireless network's name, To change the router's channel, To enable the wireless security on the router, Log ionto your router, 192.168.1.1
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware on Linksys
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
I can connected to my linksys, but the the linksys
there is nothing issue with the linksys ist chk the ipaddress which u had provided to the modem and router is in same serious for eg: if ur modem is in 192.168.1.1 ten provide ur router ip as 192.168.0.1 and also chk whether the connection type is in PPPoE and also chk whether u r able to browse through modem which is provided by the ISP....
Feb 18, 2010 | Linksys Cable Modem
My Dell lattitude D830 won't connect with linksys
Right-click the wireless icon with red X and click on View Available wireless networks. Highlight the name of your wireless network and click Connect. If it asks you for the network key, type in the secuirty key of the router and press connect. That should do it. If you don't know the wireless security key of the router, you can see it by accessing the router's Setup Page through http://192.168.1.1 on your browser. It's under wireless tab then wireless security sub tab
Sep 23, 2009 | Linksys WRT300N Wireless Router
Linksys to homeportal
In order for you to make the linksys wireless router and the homeportal 1100 to work together they should be connected via CAT5/ethernet cable, you cannot connect them wirelessly...
Oct 26, 2008 | 2wire HomePortal 1100 Router...
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
My lap top connecting to my wireless system.
Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
Try configuring or verifying the wireless settings of the router first by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4585&p_created=1165894972&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aXJlbGVzcyBzZWN1cml0eQ**&p_li=&p_topview=1
After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_created=1160185039&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAyNSZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb25uZWN0aW5n&p_li=&p_topview=1
If you cannot still connect wirelessly, let me know of the following:
- model number of the router
- operating system of the computer
- wireless adapter installed on the computer (built in or external)
- brand of wireless adapter installed
- wireless settings of the router (SSID, wireless security)
May 13, 2008 | Linksys Wireless-G WRT54G Router
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
