Question about True T-49 Side by Side Refrigerator Commercial
RE: true T-49
Dear sir,
I just brought a true -49 two door cooler last month. Last week I found the left side door didn't close by itself after I open it. I have to push it back. Is that the door hanger or something else?
Thanks.
    Scholar:
  • 149 Answers
Check the hinge position it's probably off line
Posted on Aug 02, 2008
  • billmallard Mar 22, 2011
    Then how is the door hinge re-aligned?
    Thanks
Sir, we experiencing U-12 error in Panasonic washing machine since last week. What will be the solution??
CODE U12
The door is being read as being open
Check door is closed
Check doorlatch etc.
Check door lock
Check wiring
Check electronic controller............cheers
Oct 12, 2016 | Washing Machines
Why does everything freeze in my T-49 True refrigerator
The cooling coil is probably frozen up. Shut it off and leave the door open over night. Start it up in the morning and see if its more accurate. Down the road you may find you have issues like leaving the door open in high temperatures, maybe the coil is plugged with paper, ice, dust etc. and needs to be cleaned, or maybe it was improperly charged by the last service man that worked on it. The charge should have been weighed in with a scale by the ounce. Good luck and hope this helps.
Jun 20, 2014 | True T-49 Side by Side Refrigerator...
How to adjust doors on Model T-49
How is the door out of alignment...wont close, wont open, twisted from top to bottom?
Tell us what is wrong specifically.
Oct 27, 2013 | True T-49 Side by Side Refrigerator...
One of the doors on the True Cooler model T-49 will not close all the way.
Check for loose hinges & or a damaged gasket. Make sure door is not warped. Parts can be acquired from Refrigeration Hardware Service in Colorado.
Oct 27, 2013 | Furniture
True 3 door refrigerator model#GDM-72 door does not self close
hi, I lost a part of the true cooler model gdm-72 door part that let the door side itself to close
Nov 01, 2012 | True Refrigerators
Left door doesn`t close by itself
check the beading correct may be twisted / Bottom foundation screw adjust / Check bottom door hinges plastic sleeves damaged.
Mar 22, 2011 | True T-49 Side by Side Refrigerator...
Dear sir, My Name is Ajay, from Qatar i brought
put a big big big huge enormous fan behind the tv with back cover off
to vent the board that is overheating......try to find wich chip or parts that is overheating with a laser thermometer.
that particular part will be like 40 degree more than others
Oct 27, 2010 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
I just brought this unit and i had brought another one last month and i can not find the silver package with the print head in it. i just open the box for the new one i brought yesterday and i can not...
There are few printers which has the printhead assembly pre-installed and all you need to do is install the cartridges.
If not
Open the Front access door ( front panel door ) and check if the Printhead package is inside it. If not call the Tech support and request for the Printheads
Sep 25, 2010 | Office Equipment & Supplies
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Door lock problems for 2003 Honda
sounds like the central locking motor is gone
Aug 12, 2009 | 2003 Honda Civic
True T-49 Side by Side Refrigerator Commercial Logo
176 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
