Question about Whirlpool Washing Machines
New coin operated commercial washer rinse cycle water level very low?
Washer_tech
  • 164 Answers
SOURCE: repair the maytag commercial washer with out coins selector
your bearings are going bad. you need to replace the bearing on the top of the brake packag and might have to replace the tub bearing also
Posted on Dec 18, 2007
  • 65 Answers
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Posted on Jan 27, 2009
dragonsthatk
  • 547 Answers
SOURCE: LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Posted on Feb 12, 2009
SOURCE: high speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
Whirlpool heavy duty commercial washer, mod# CAM2742TQ0. Washer does not fill all the way on rinse cycle set on large load.
The service manual shows this machine as a timed water fill. When the washer is filling in rinse, is the flow strong? If not, check the screen on the water valve at the hose connection. If clogged, you can try and clean it with an old tooth brush and a spray water bottle. If not clogged, there are two water level switches. You could have an issue with the high level switch.
Jun 24, 2016 | Whirlpool Washing Machines
Whirlpool commercial top load coin washing machine with only Luke warm water
i would take hoses off washer and check screens infill valves first.valve may have a thermister in it to control water temp this may be bad.may have to call a tech.
Dec 10, 2013 | Whirlpool CAM2752RQ Coin Operated...
The level of water in the rinse cycle is extremely low to the point that the clothes are not rinsed. Why is there such a large differential between the level of water in the wash and rinse cycle? How can...
Low water pressure or bad inlet valve, or clogged screens in fill hoses, check flow with hoses disconected these will be the causes! check hot and cold fills than check warm, any differnt all setting work?
Aug 23, 2011 | Estate ETW4400VQ Top Load Washer
I have a whirlpool washer that only fills up half way in the rinse cycle, is this normal
I have a similar machine and was wondering the same thing.... can this be set to fill up fully on the rinse???
Sep 10, 2010 | Whirlpool CAM2752RQ Coin Operated...
Just bought brand new commercial coin operated washing machine top load...everything is level tried washing a load and at the spin cycle the machine vibrates so bad it seems like it's going to take off. ...
maybe when you were moving it, one or more of the springs that keep the drum centered came off,unhook everything,drain it,tip it over face down on a piece of clean carpet, make sure everything is in order,all supports are in place, 2 people to tip it
Jan 31, 2010 | Whirlpool CAM2752RQ Coin Operated...
Rinse cycle water level
I would cheak your drein hose ithey should be higher then the tub of washer.If not remove hot and cold hoses from tap and washer and clean screens or get ne ones good luck:)
Apr 04, 2009 | Whirlpool CAM2752RQ Coin Operated...
High speed drum rinse ..drum not spinning during rinse cycle
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
