Canon mp150 error code E8 does this mean that the printer is useless even though we have cleaned the ink pads?
Re ; Canon MP150 printer error "E8".
We found a blog that explained that once this error appears, even if you clean the ink pads as we did you cannot erase the error message. Therefore unless you pay a call out fee, not worth it in comparison with a replacement printer, the printer is of no further use. An "extermination" code it would appear!
Posted on Jul 24, 2008
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Received message ''the waste ink absorber is full'' What can I do?
You will have to replace the waste ink pads. There should be two of them on the right under the print head in rubber containers. It could be a messy job though. I think the pads on that printer has a metallic strip for detecting full condition. So you can't reuse the pads even if you clean them up.
Sep 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer flashing E8
E8 means Waste ink absorber full, or platen waste ink absorber full so reset ink also check the waste ink pad and clean
Aug 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 8
Dear sir your problem is or E8 mean
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Problem absorber full
Here and hope you find it useful. use the mp150 procedure
May 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer show E 2 7.
Hi zaris79,
The E27 code means that the waste ink absorber is full. You'll need to clean the absorber pads and reset the error code. Here's how:
The absorber pads are on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way (you can move them to the left by hand if the printer is off). You might need a flashlight to see the pads - each is positioned in a rubber retainer.Take the pads out of the retainers with tweezers and clean them with warm water. If there is ink in the rubber retainer, wipe it out with a paper towel. Finally, put the clean pads back into the retainers.
If the printer does not realize that the absorbers are clean, it may still give you the error code - here's how you reset it:
1)With the printer powered off but connected to a power source, hold down the Stop/Reset button and press Power (the power light should light up).
2) When the Power is lit, hold down the power button, and press the Stop/Reset button two times (then release both - the printer should enter service mode. (Waiting for menu selection)
3) Press the Stop/Reset button 4 times to reset the waste ink counter.
4) Turn off the printer, and turn it on normally. That should do it.
For your reference, here is the complete list of error codes for the MP150:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Can not print
replace your cartridges clean the ink splatter sponge and make sure the cartridges are set in correctly and the printer is aligned this is crutial this will be in program specs
Jun 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
1,211 people viewed this question
jasbo
jasbo
