posted by aneagoe on Jul 22, 2008
I need a solar power cell to recharge continuously 2 x 3V batteries capacity of 1300mAh.
Best Solution
posted on Jul 28, 2008
Here is a link to a site for solar panels and all the required information you need for your application:
http://www.firemountainsolar.com/
Here is their phone number also: 1-877-230-7710
Just give them a toll free call and their friendly staff will set you up with the equipment you need for your project. This is where I bought the solar system for my RV. They are the best source for solar sells and info on the internet. I researched 20 companies before I went with Fire Mountain Solar. I was fully satisfied with every aspect when dealing with this company and they stand behind their work and their products. You can not go wrong with them.
I hope you find this information priceless. If you do please take the time to rate my solution fixya as I found you the best source for your solar cells from the best company that I deal with myself. If you need any help in the future I will help you for free again. I do this for a hobbie. geokohler@gmail.com
Rating Locked! (?) aneagoe has rated this solution as Helpful
This Problem Also Relates To:
Coleman (5040B750) Patio Heater
Honeywell Digital Heater Fan with Remote
Honeywell HZ514 Baseboard Heater
Honeywell HZ-709 Oil Filled Radiator Heater
Black & Decker BDOH100 Oil Filled Radiator Heater
Honeywell HZ365 Ceramic Compact Heater
DeLonghi (HGHTBBH100) Baseboard Heater
Can you Help with these Heaters problems?
Honeywell Programmable Thermostat Heater
Stuck at 79 degrees
Stuck at 79 degrees
When my thermostat is turned... Answer This...
Goodman GMS90703BXA Heater
Heat Starter motor constantly...
i have a goodman 125-4 and the... Answer This...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Energysaver 1004FTR
Energysaver 1004FTR
heater wont start Hi we have... Answer This...
Repair Service
Find Heater Repairman Near You:
