Question about Whirlpool GEW9250 Electric Dryer
Excess lint Dryer is 4 years old. Always has a lot of lint in the exaust. Clean the screen every time. Need to vacume the 15' eaxust tube every year. Service guy says all is OK and no answer for the excess lint. Any help? Thank you
  • 958 Answers
Well lint comes from the clothes so the more you use the dryer, the more lint you will get. check the lint filter, it could be damaged and not catching the lint as it should.
cheers,
drcool
Posted on Jul 22, 2008
Maytag dryer model #PYE2200AYW how to remove lint compartment once I removed the screws in the front
Instructions
Things You'll Need:
Nylon scrub brush Liquid detergent Vacuum
1.Remove the lint screen, which usually is located in the front of a Maytag dryer. Gently pull it up and out, and remove the lint with your fingers.
2. Use hot water and wet both sides of the lint screen. Use a nylon scrubbing brush and a little bit of liquid dish soap or laundry detergent to scrub the screen clean of lint and fabric softener buildup. Rinse both sides thoroughly with hot water. Towel dry and replace the lint screen when dry. Maytag states that owners should do this every six months.
3.Clean the exhaust every two years, as recommended by Maytag. Whoever installed your dryer had to install the exhaust vent. Unplug your dyer and unscrew the vent from the back of the dryer. Use a vacuum attachment or your hands to remove any clogged lint and replace. You may need to do the same thing to the other end that is attached to the wall.
4.Clean the dryer cabinet. According to Maytag, a professional should remove lint from the dryer cabinet every two years. This may be a good time to have him clean out the vents as well, rather than doing it yourself, if preferred.
5.Clean your lint screen on a regular basis. Maytag states that you should clean the lint screen with your fingers before using the dryer each time. Be sure to replace it all the way so it can work properly.
Mar 10, 2011 | Maytag Dryers
Clothes come out mostly dry, but need to run a 10 or 15 more minutes to completely dry. Towels need 2 drying cycles. Lint filter is clean. Lots of lint behind dryer and I notice a lot of lint on...
you need to clean out the dryer.somewhere lint is blocking the air movement.pull off the vent line,if it's long blow it out with a leaf blower,then clean out the duct that the lint filter slides into and vac out the cabinet where the motor is.if it's gas you should do this once a year electric once every two years.
Feb 17, 2011 | Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
My ge Profile dryer is 5 years old and for about a year the drying process became slower and slower as the heat within became cooler and cooler! Im thinking thats the heating element. My question is how do...
This is dued to lint build up in the dryers venting tubes. If you completely tear the vents off and clean them inside thoroughly it will run like ne again. It will be better to replace accordian stle tubes than to clean them if that is what you have on yours
A moister sensor detects the build up and keeps the heat in check
Jul 01, 2010 | Dryers
Dryer works bu not lighting the furnace.What do u think?
Two things come to mind when this happens. The duct work is totally plugged up or the spark ignitor is out of order.
Check the vent tubing by completely disconnecting it and cleaqn thoroughly clean. I see one once I took apart and filled a 15 gallong trash bag full of lint. The dyer was three years old and had a 10 foot vent tube. 4 feet of tubing is always recomended at the longest length used. If longer it needs to be cleaned evey few months for 100% efficiency
If the tubing is clean turn on the dryer and listen for the click the sopark ignitor makes to light up the burner. If no click is heard the ignitor is bad
Apr 09, 2010 | Kenmore 73952 Gas Dryer
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer gets hot and drum is turning clothes are not drying. cleaned lint tray and removed tubing venting outside and the dryer is making a whining noise. the dryer is only 14 months old
If the drum is turning and the dryer is getting hot, then this is good news, as it means that the dryer is mechanically sound.
First check to see if the internal workings of the dryer are not blocked by running the dryer with the vent tube detached. If there is lots of warm moist air coming out the hole in the back of the dryer where the tube should be, then your dryer is fine.
Next, if you've checked the tube that connects the dryer to the wall or floor and it is clear, then on to step 3.
Probably you have a blocked or severely restricted vent tube from the wall or floor to the outside. Over time, these always become clogged with wet lint that builds up into a crust on the walls of the tubing.
Find the exhaust exit on the outside of the house and run a sewer snake up into it to see if you can open a hole in the blockage. If that works to help the air flow, then you need to replace the tubing from your laundry room to the outside, as it is probably a solid crust of lint that has built up over years.
Again, the good news here is that your expensive new dryer is probably fine.
Jun 10, 2009 | GE Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer screen
No. The accumulation of lint in the dryer screen generally doesn't have anything to do the amount that ends up INSIDE your dryer. Too little lint is not a bad sign. It's dependent upon the type of clothing you are drying as well. If the clothes are not "lint givers" (like cottons and wools), you generally won't see a lot of lint in the dryer screen. Dryer screens are not perfect, either and some lint always gets through. As long as there are no holes in the screen and you have it seated correctly, and you clean it after each use, you shouldn't have any problems.
What affects dryer performance the most, is your vent hose and routine cleaning. The simple rule of thumb is: The SHORTER and STRAIGHTER the vent hose the BETTER. The vent hose should also be cleaned thoroughly periodically. I recommend once per season. That's about 4 times per year. What causes the lint to back up into a dryer is when the vent hose becomes kinked or clogged. The lint is mixed with moist air when it leaves the dryer. If it has no where to go, it starts to accumulate and stick in areas of the vent hose that are sagging, or at tight bends. Eventually, the vent becomes so restricted that the lint ends up inside your dryer. This causes the heating circuits to overheat to eventual failure. Not to mention, accumulations of lint inside a dryer can cause a fire. I have personally inspected dryers that were so full of lint that the dryer hose contained about a gallon of water from condensation and the inside showed evidence of multiple fires. If you need further info, I have an article I wrote up explaining all of this under "Tips and Tricks" under my profile. I hope this helps you.
Apr 06, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
219 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
