Question about Refrigerators
I have a Boler Trailer [Cadet] 1994 ,and the fridge is not getting cold. The pilot light is working well. The model is a Dometic RM183. On the cannister it's marked ARCTEK, serial #560683,made in U.S.A. Any suggestions.
I had this same problem and here is the possible solution.
The older fridges used amonia and water for a refrigerant. If it sits for a time the two seperate. Remove your fridge and turn it upside down and back again... let it sit for a bit in both positions. Occasionally turn it on.. either with gas or electric if so equipped. The process of heating and mixing the amonia and water will sometimes do the trick. When you notice its starting to get cold let it run a while.
Posted on May 14, 2009
Hi i have RGE 400 lpg fridge freezer its 10 yrs old on my catering trailer and used daily. Its stopped cooling the fridge and freezer compartments but the pilot light is ok. the metal tubes at the rear of...
I suggest you to check the Vents. I had a similar issue where my 12v compressor car fridge freezer stopped working and I found that I had put the Fridge Cover the other way round which accidentally covered the vents
Nov 22, 2012 | Dometic RGE400 Top Freezer Refrigerator
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Travel trailer refrigerator will not get cold
Model 2652 Refrigerator The fridge has been perfct till this last trip. the auto light is on and its not getting cold no red lights and i have pluged in as well as unpluged propain is full but i see some yellow dust inside the big cyinder.we may have left the frezzer door open for a couple hour.
Jun 04, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
591 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
