Question about Linksys Wireless-G WRT54G Router
Server not found
When I use my WRT54G ver. 6 sometimes it works fine. However, I do get the "server not found" quite a bit. When I'm on my desktop all I have to do is hit the retry button and it loads usually the first time. But when I'm on my laptop it's not that easy. Usually, I can't get it to load right a way. Sometimes I can't get it to load at all. I talked to my internet provider (thinking that it may be their problem) and he told me to try using the internet without the wireless by plugging the dsl modem directly into my desktop/laptop. When I did this I had no problem connecting to any site on the first try. So, I know it is a problem with my wireless router. The tech at my IPS told me that it was probably a bad wireless box. What I don't get is why sometimes I can connect to most websites and other times I can't. Even the most stubborn websites (the ones that I almost always can't connect to the first try) I can get in using the "cached" function but that only let's me see the home page. If I connect to a link that way I will just get "server not found" again.
I've uploaded the latest and greatest IE/Firefox. I've reset both my dsl and wirless boxes a number of times. I've downloaded all the windows xp/vista patches, etc. and it still happens. So, my conculsion is that it has to be a problem with my linksys box. What do I do?
  • 137 Answers
Have you checked your HOSTS file? It may have been tampered with somehow. I ask this because you're having issues with both browsers. If it's not a DNS problem, it may be linked to hosts file, which determines what websites you can get to see.
Posted on Jul 22, 2008
Computer says server not found
too many causes.....and what OS are you using ?
boot into safe mode and run scans with your anti-spy/ad-ware tools
(Malwarebytes.org is a good free one....and it works in Safe Mode..for 32 or 64-bit systems.)
Talllon41
Sep 06, 2012 | HP Pavillion s7420n PC Desktop
Hi, I have a Sony Ericsson Xperia Neo, and every time I want to connect with my WIFI the router reboots. This issue only happens with my Sony Ericsson Xperia Neo, other phones and devices work just fine....
Just had same problems with my brand new Xperia Mini Pro and old WRT54G ver 5. Every time I connected with WiFi the router restarted (once it returned to factory settings). I updated the router firmware to latest version (1.00.6 to 1.02.8) and after this it works fine.
Best Regards
Peder
Sep 17, 2011 | Linksys Wireless-G WRT54G Router
My wireless router with ports works fine with hard wire connect. I can' t get my laptop to connect wireless. Reset unit and all. can u help Lynkys, wrt -G ver. 6 Used to work fine. Cisco, says by another...
It can be fixed most likely unless its just an old unit that has burnt out. Try reinstalling the software that came with it and rebooting your system. If that doesn't work search for discussion in wireless router discussion forums.
Nov 09, 2009 | Linksys Wireless-G WRT54G Router
Wrt54g ver 6 driver download link
Router's do not have drivers. If you are talking about firmware you can get it from here
http://downloads.linksysbycisco.com/downloads/WRT54G-v5v6_1.02.5_fw.bin
You just have to configure it. Here's the manual that may help you out with the configuration process
http://downloads.linksysbycisco.com/downloads/WRT54G-v5_ug.pdf
Post back if you want me to walk you through it.
Sai.
Apr 12, 2009 | Linksys Wireless-G WRT54GS Router...
Frimware Upgrade
Apparently not, but I'm guessing you already knew that.
http://www.linksysbycisco.com/US/en/support/WRT54G/download
Look carefully at the label and the firmware installed in your router. The 1.02.5 is listed for 5 and 6 only and version 8 is for 8 only. There is no 7 listed, so it was either a special run or there is just no firmware upgrade for it yet. It must have been perfect :-)
Carl
Mar 24, 2009 | Linksys Wireless-G Broadband Router
Not connecting
reset the router and then upgrade the firmwere.
-tg
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
I would like to know the steps to setting up an internet connection using a linksys wrt54g ver.6 using the provider comcast . It is intended for 2 laptops, and a desktop.
if u have the cd that came with your router it will give u step by step dierections. it is very iis to install.just put it inthe drive and do what it says.
Dec 27, 2008 | Computers & Internet
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Linksys Wireless-G WRT54G Router Logo
64 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
