Question about Whirlpool Duet GHW9150P Front Load Washer
HF error code
6 year old Duet which early on began flashing"HF" error code- water inlet problem. I ignored until past year when problem became very frequent requiring 'authorized' service. He replaced a control valve, finding no problem with water system. Little help, as problem persists. New "authorized' repair person suggests replacing main computer control module and flow valve.
Suggestions before I spend more for unwashed clothes? Telephone Whirlpool service line is of no help and very hard to access.
  • 3,230 Answers
check this-
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
good luck
Posted on Mar 28, 2009
  • 5,911 Answers
You may have tried these options already, but here's a link I posted that explains the FH error and how to determine the cause of the problem.
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
I'm not ruling out the Central Control Unit, but the information I researched mentions nothing about it. I would check the simple things first, like making sure you don't have a siphoning issue and making sure your drain pump is not obstructed. I would hate for you to spend money on a simple problem that could have easily been remedied yourself. Have these options already been tried? If the problem has gotten progressively worse, you could very well have debris clogging the drain pump and restricting water flow. please read through the information and let me know if you have any further questions. I hope this helps.
Posted on Jul 22, 2008
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirl pool duet washer with error code
try this:
Or
  • If there is no water in the unit:
  • If there is water in the unit:
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Apr 28, 2010 | Washing Machines
WHAT DOES ERROR CODE HF MEAN
I did some research on your problem and I came up with this. Good Luck...I hope this helps, Please rate me Thank you ------------------------------------------------------------------------------------------------------
HF Code = No water detected entering machine or Pressure switch trip not detected.
Or
Dec 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code hf came up on my washer
The HF or FH indicates that No water detected entering machine or Pressure switch trip not detected.
Or
ACTION
  • Verify CCU operation
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hf is showing as an error message. what does it mean?
Details of HF error message and procedure to check and solve the issue is given below:
Or
thanks,keep updated and please do accept and rate the solution.
Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FLASHING HF CODE WILL NOT WASH OR UNLOCK
* Verify there is not a siphon problem
* Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
* Check all hoses for possible leaks
* Verify pressure switch operation
* Verify flow meter operation
* Verify CCU operation
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
Or
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
globul1a.gif If there is water in the unit:
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
Or
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code HF
Or
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tub won't fill
hi there,
Or
best of luck....
Feb 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
529 people viewed this question
Dan Webster
Dan Webster
Sal De
