Question about Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 inch EDTV
This tv was bought new in April of 2005. We have never experienced any picture problems. The other night we turned the tv off left for about 2 hours, came home turned the tv on saw some yellow and red lines then the screen went black. We have sound but screen shows nothing!
We have disconnected and reconnected all cables. Still no picture just sound! Do you think its the board that I keep hearing about in these modesl?
Thanks
  • franklin2230 Jul 29, 2008
    This tv was bought new in 2005. We have never experienced any picture problems. The other night we turned the tv off left for about 2 hours, came home turned the tv on saw some yellow and red lines then the screen went black. We have sound but screen shows nothing!
    We have disconnected and reconnected all cables. Still no picture just sound! HELP!!!!!!
  • kathrynrose8 Jan 17, 2009
    We have a Zenith P42W46X and all we get is snow on our picture. Does anyone know what is wrong with this tv? Thanks for any help you can give us.
    Scholar:
  • 170 Answers
Common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Posted on Jul 22, 2008
  • Scott Henderson
    Scott Henderson Jul 22, 2008
    not test pins are usually a 4 pin connect on the control board.
    usually pins 1&2 shorted gives test pattern.
Howdo you fix and picture that is fuzzy and whiteallthe time i have a 42 inch plasm tv
If the Vs and Va voltages to plasma panel is abnormal, this could happen. Check these voltages. Both these voltages are critical, and should match exactly the same as marked on silk screen at the back of the display panel. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 23, 2016 | Zenith P42W46X 42 in. Plasma EDTV
How do i turn the television on i just bought it from the store
Either by your remote or manual. Some models have a master rocker switch close to the ac input where your cord plugs into. That kills all power to the set for vacation purposes.
Sep 28, 2010 | Zenith P42W46X 42 in. Plasma EDTV
I have no picture but i have sound any suggestions
Replace 6870QZE013C or 6871QYH053A (more likely).
The second is the Y-Sustain board, located to the left of your TV when looking from the back.
This is the one that usually burns and the fuse on it is likely shorted. Do not replace it, it will burn again.
Feb 04, 2010 | Zenith P42W46X 42 in. Plasma EDTV
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the...
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Oct 08, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Picture on big screen
Chances are, if it's an older set, componants have changed value through use over time, which also includes the picture tubes and associated driver circuits. The way to compensate for this color drift is through adjustments. Either turn the red down a little, or turn the blue and/or green UP. Be carefull though as there are potentially dangerous voltages in and around the circuit boards and picture tubes.
Jun 29, 2008 | Zenith P42W46X 42 in. Plasma EDTV
P42W46X
take visa or mastercard to local best buy for new tv. sorry
May 26, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 in. Plasma EDTV Logo
619 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
