Question about Friedrich Heating & Cooling
Air conditioner thermostat does not work - Friedrich Heating & Cooling
  • philnyc Jul 22, 2008
    Its a Friedrich CP10.... is it easily replaceable?
  • 958 Answers
Replace the thermostat. there is no repair for a bad thermostat
Posted on Jul 22, 2008
  • francis rivero Jul 22, 2008
    yup...it is just being hold on by two screws...
    cheers
    drcool
Air conditioner frezing up.clean filter and air conditioner but still ferzing up
If its doing it over night or in several hours, you need to check the thermostat. Turn it all the way to the warmest setting and listen for the compressor to shut off. If the compressor keeps running at the warmest position your thermostat is shorted. If you do hear your compressor shut off , and the thermostat is working, you are probably low on refrigerant.
Apr 14, 2011 | Kenmore Single Room Air Conditioner
Air conditioner works fine but heat won't kick on
Check RV is working. And also keep thermostat setting +29 and heat mode.
Dec 09, 2010 | Ruud Matching Split Air Conditioner
Thermostat dial broke and huge ice pushed out cover. Fan still works ok.
dear sir
i think in your air conditioner,s thermostat is not working because there huge of ice on unit. thermostat control to compressor for desire temperature, when temreture reach till desire tempreture it,s cut supply for compressor . and make balance on cool air.
please replace thermostat for solve this problem.
hope answer the question
thank you
please vote!
Oct 02, 2010 | Sharp AF-R100DX Air Conditioner
My air conditioner was working fine until it just stopped working. Thermostat shows no readings whatsoever. The unit outside dose nothing as well. We have changed the filters, reset the breaker switches...
Sounds like the transformer burnt out..or the t-stat went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 20, 2010 | Heating & Cooling
Two air conditioners & two furnaces with one thermostat
use relays to combine the to and isolate from each other or observing polarity's, you should be able to parallel the connections from your thermostat
Jan 28, 2010 | Dometic Rooftop RV Air Conditioner
Changed thermostat to digital, and it wouldn't work so i changed
If the fan and compressor are running then the thermostat is doing its job.
May 14, 2009 | Dometic Rooftop RV Air Conditioner
Fan working but thermostat is not
You can judge if your thermostat is working by listening for a click when you rotate the knob.
Feb 17, 2009 | Friedrich QuietMaster Electronic SS12J30D...
Fan setting only works
Air Conditioners have a fan speed relay built in the unit, faster for cold air and slower for warm heated air. It is very possible that your relay is defective
Oct 20, 2007 | Ruud UAMB Air Conditioner
My air conditioner doesn't turn on, what do I look for?
If your room air conditioner doesn't go on at all: 1) Check the power source first: be sure it's plugged in and turned on. 2) Then check the outlet by unplugging the air conditioner and plugging in a light that works (only for standard-voltage models--do not plug a light into a 220/240-volt receptacle!). 3) If the light doesn't go on, the circuit has probably overloaded--check the electric panel or fuse box and reset the breaker or replace the fuse. 4) If the light works, it's likely that the air conditioner's switch is faulty or the thermostat needs adjustment or repair. 5) Be sure the thermostat is set to "cool" and below room temperature. 6) Refer to the manufacturer's instructions for thermostat repair. If adjusting or repairing the thermostat doesn't solve the problem, unplug the unit and call an air conditioning technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
343 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
