Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Ionic Breeze Quatra
I brought one to China and realized that the voltage in China is 250V and the unit is 110 to 120V. I thinks it just blew off the parts. How do I get it fixed. It is made in China by the way.
    Scholar:
  • 45 Answers
Check online to see if you can purchase just the replacement parts and fix it yourself. Chances are, however, you might be forced to send it to the manufacturer to get it repaired.
Check your local stores (WalMart, Target, etc) in the luggage area and get one of those power converters that you use when you travel to a different country. I wouldnt leave home without it. it pays for itself when you consider how much stuff you can literally destroy and cook off because the voltage is different than what it is here in the USA.
Posted on Aug 20, 2008
Does not power on anymore
Hi.
To get parts or repair you need contact Ionic Breeze support. Here contact page.
However, if the model was manufactured before 2007, read the text below, in that case do not get the parts.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
I think your unit is pre 2007. I suggest not proceeding with the repair.
Regards.
Ginko.
Sep 17, 2010 | Sharper Image Ionic Breeze 3.0 Air...
My Quadra Ionic Breeze, has a small glowing fire within it at the base. There is a smell of plastic/electric burn. Though the odor did cover the odors in my house, I think I have a fire hazzard on my...
the ionic breeze uses high voltage to move/filter air .. if the insulators break down there will be an arc such as what you see .. there is a way to dig out the carbonized material and seal it with materials that can handle the high voltage but any repairs are costly .. its unlikely you can repair it for less than a new conventional filter .. the ionic breeze was unique and expensive but didn't move a lot of air ..it was quiet but often produced some ozone .. long exposure to ozone is not a good thing .. here is a site where you can learn more about your unit
http://en.wikipedia.org/wiki/Air_ioniser
check out where it says "Consumer Reports court case" ... that said, the electrostatic concept does probably remove small particles that are hard to do with conventional filters .. the arcing you see in your unit is indeed not safe . ... here is more that you likely don't want to hear..
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
in the next one look down where it says "Ionic breeze" under "helpful information" that will frost the cake
http://www.sharperimage.com/Pages/Helpful+Information/#ionic_breeze
i am sorry to say that your expensive ionic breeze is not safe and not repairable.
Aug 15, 2010 | Sharper Image Professional Plus Ionic...
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
I believe that the motor on my Ionic Breeze unit is broken. Can I replace it??
Ionic breeze units don't have motors. I thought they just moved the air by ionization.
The unit might need to be cleaned. Check you owners manual or the manufacturer for instructions.
Dec 09, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
I have an Ionic Breese Quarda that just stopped working all of a sudden. Is there someone who can walk me through some basic fixes? Company out of business I'm told.
The high-voltage grid wire(s) most likely broke -- unfortunately, there is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended. Even if the reapair is done, the unit will likely fail again, soon.
When my reapired units failed, I got units off E-Bay -- they didn't last very long either.
I'm now in the market for a more rugged ozone-generating air purifier.
Charlie
Sep 21, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
