Question about Whirlpool Washing Machines
F 70 code, and/or F 71 code - Whirlpool Washing Machines
Washer --
The interface fried, probably lightning causing a power surge, a new one @ $152, + service call. Getting the part is a problem. It's 14 months old.
Our last washer was purchased second hand, we used it for over 20 years and it was still working when we replaced it.
paweb
Posted on Jul 25, 2008
What production year is serial # 75381 ?
looks to be made from 70-71 70 SN numbers start at 52527 71 SN start at 88184, I googled that question
Mar 19, 2015 | Winchester Model 94 Sporter 30-30
Cannot tune channels eg channel 9 10 7 only gets sbs abc nu-tec mod NUE 1958 18.5 " lcd
i had same prob untill i pluged it into a wall antana went auto setup australia DTV only and i got 7, 73 ,70, 71 , 90, 99,9,10,1,11, when pluged into a portable tv antana i lost 7, 73 ,70, 71 so that how i fixed my problem
Jan 06, 2011 | Televison & Video
How can i get the tel number and address for the brandt company?.
Brandt is a french company who supply ovens thru retailers in the UK, not sure about the US.
They are at
18 Rue du onze octobre
45140 St Jean de la Ruelle
France
Tel: 0033 238 70 70 70
Fax: 0033 238 70 70 71
Dec 10, 2010 | Ovens
Can't find Lexmark 70 or 71 cartridge local are there other options to use of 70 or 71?
Aside from #70 and #71,#75 mono cartridge is also compatible with Lexmark X4270 printer. I hope this one's available in your area. Good luck!
Jul 09, 2010 | Lexmark X4270 All-In-One InkJet Printer
My dryer shows F 70 on the panel
For a Whirlpool dryer F70 is an electronic control issue. It can be as simple as the wire came loose off the control in the top console or as complex as both control board and console electronics have failed. Here is what the manufacture says:
F:70
F:71
No
Communication
Between
Electronic
Assemblies
F:70 / F:71 flashes when there is no communication between
the machine control and the console electronics.
■ Check console electronics harness connections to the
machine control.
■ Replace the machine control electronics.
Apr 23, 2010 | Whirlpool Dryers
Telewst Eurovox codes October 10th
new codes 5a 01 .........cf 53 0c 33 79 61 71 85..................d2 f9 3f 22 cf a7 d6 c9
Oct 09, 2009 | Televison & Video
V chip code
Good Day;
Go to page 70, 71, 72 of your owners manual.
Good Luck, big IRISH.
Sep 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Clear BIOS settings
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory. However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
Code: O 70 17
O 71 17
Quit PHOENIX BIOS
Code: O 70 FF
O 71 17
Quit GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
Code: O 70 2E
O 71 FF
Quit
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Jul 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Nov 20, 2007 | RCA D52W15 TV
Washing Machines Logo
183 people viewed this question
Dan Webster
Dan Webster
Sal De
