Question about Magicard Opera 100 Card Printer
Printing problem when i have the card ready to print i click print then i click ok so it can print the small printing window disappear but it doesn't print i used to use it in window xp now im try to do it in windows but doesn't print and i try in windows xp again and is not working either . what could be the problem ? any driver ? update ?
  • 71 Answers
Hi JuanU,
Which version of Windows are you running now? Vista?
If it is Vista, you will need to use the newer 'UltraDriver' for the Opera printer (V1.3.0.0 Issue 1).
This can be downloaded from Magicard's web site here;
NOTE!!! This driver will ONLY work with the following operating systems: Windows 2000, XP, Server 2003 and VISTA. If your PC has a different OS from those above DO NOT install this driver!
If you have an 'older' Opera printer which does not have an 'E' in the serial number, you will need to change the 'PRODUCT ID' from 2000 to 2800 before this driver will recognise the printer.
This is quite simple to do. Download and install the Magicard Support Utility Version 3.13 by clicking on this link;
Run the Utility, select 'USB' for the comms port.
When the other tabs open up, select 'Statistics / Commands'.
In the 'Quick Command' box type;
Then click 'Send'.
Exit the Magicard Support Utility, and unplug the printer's power cable.
Now, install the UltraDriver version Issue 1.
When the driver install has finished, plug the power cable into the printer. The hardware wizard will finish the installation and you will then see the 'Magicard Opera' printer icon in your printers folder.
It should then work fine.
Let me know if you have any problems.
Posted on Jul 22, 2008
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
My printer wont print. I have recently upgraded to windows 7. have downloaded the new driver. but it wont print. i have tried a full reset, partial reset, taking out ink and restarting, putting ink back...
You need to check the hardware functionality of printer first. Make a copy from printer and check if it prints fine. If hardware is okay. You can try following steps on computer.
1- On computer keyboard press Windows(flag) button and R at the same time
2- This will open a small Run window
3- Type devmgmt.msc in Run window and click OK
4- This will open Device Manager window.
5- Right click on psc 2410(2400) entry under "universal serial bus controller" and 'imaging device' and click delete/uninstall/remove. Printer's entry should disappear from there.
6- Disconnect usb cable from printer and computer
7- Wait for 50 seconds.
8- Connect the usb cable to printer and computer.
9- This should install the drivers automatically.
Dec 23, 2010 | HP PSC 2410 All-In-One InkJet Printer
Default Printer Issue
The wrong printer is set as the default. See the image below for an illustration.
What to do
Open the Printers or Printer and Faxes folder and locate the correct printer icon. To do this:
    1. -In Windows XP, click Start > Settings > Printer and Faxes (or Start > Control Panel > Printers and Faxes).
      -In Windows Vista, click Start > Control Panel > Hardware and Sound > Printers.
    2. Right-click on the printer icon, and click Set as Default Printer. A check mark displayed above the printer icon now identifies it as your default printer.
    3. Try printing again.
Topic 3: Printer is "Offline"
The printer is set to Offline and the printer icon appears washed-out. See the image below for an illustration.
What to do
  2. Right-click on the printer icon, and select Use Printer Online.
Topic 4: Printer is not Ready
The printer is in an "Intervention Requested" state (e.g. paper jam, paper out) but no Windows print error notification message is displayed.
The print job cleared the print queue. This means the print queue icon has disappeared from the notification area ('systray') of the task bar. The printer is holding the job, however, until the the printer is returned to a ready state.
What to do
Check the printer LCD, or operator panel menu, to verify that the printer is in a ready state. If not, return it to the required status.
Topic 5: Printer is Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
This is typically an end user error. Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do
    1. Double-click on the print queue icon to open the print queue. (This may also appear as a small printer icon in the lower-right notification area of the task bar.)
    2. Click on Printer in the upper left-hand corner of the menu bar.
    3. Is there a check mark next to Pause Printing?
      -If yes, click on Pause Printing to turn off this Windows feature.
      -If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Topic 10: Windows Print Spooler Issue
A problem with the Windows print spooler is preventing successful printing.
What to try
Stop and start the Windows print spooler. To do this:
  • -In Windows XP, click Start > Control Panel > Administrative Tools > Services, click on Print Spooler, click on Stop the service, and then click on Start the service.
  • -In Windows Vista, click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. Right-click on Print Spooler, and then click Stop. Finally, right-click on Print Spooler again, and then click Start.
Remove the first print job from the print queue. To do this:
  2. Click on the first job listed so that it is highlighted.
  3. Click on Document in the top menu bar.
  4. Click on Cancel.
  5. Click Yes when you see: "Are you sure you want to cancel the selected jobs?"
Click here for illustration.
Topic 11: Other Issues
Other possible causes of a print job not printing include:
  • -USB connection problem if locally connected only.
  • -Firewall issues preventing communication.
  • -Workplace virtual private networks (VPNs) preventing communication. VPN tunneling may be required to ensure successful communication. Enabling this feature may require network administrator approval and assistance.
  • -Document formatting.
  • -Driver settings.
  • -Application-specific issues relating to the application's Printer Setup.
Topic 12: Last Resort
If you have tried all of the above suggestions to no avail, try the following:
  1. Reboot your computer and try printing again.
  2. Turn the printer off and on, and then try to print again.
  3. Install a different printer driver, e.g. PCL, PostScript, HBP, or XPS driver.
Dec 14, 2010 | Lexmark Optra T610 Laser Printer
How to solve 'error S01'?
1. Verify USB cable is connected directly from USB port of printer and the USB port on back of computer. If not, connect directly to both the printer and computer and try to print. If the printer does not print, go to step 3.
This is especially important if you use the print icon to print from within applications. If the Brother printer is set as the default printer, it will have a check mark. If it is not set as default:
To set your Brother machine as the default printer, RIGHT CLICK on the Brother printer and select SET AS DEFAULT (PRINTER).
A. Click on START, RUN
B. Type: CONTROL PRINTERS and click OK.
C. Locate the Brother printer in the list and hover your mouse over the Brother printer icon. Below is an example of what you may see:
Status: Ready (Could also state: USE PRINTER OFFLINE or PAUSED)
Documents: 0 (Could be any number)
D. If there are any documents waiting in the queue, right-click on the Brother printer and select CANCEL ALL DOCUMENTS, depending on your operating system. This should clear the queue.
E. If the status states: USE PRINTER OFFLINE, right-click on the Brother printer and select USE PRINTER ONLINE depending on your operating system. This should set the printer driver ONLINE.
F. If the status states: PAUSED, right-click on the Brother printer and uncheck PAUSE PRINTING. This should allow the printer to resume printing.
G. If the status is ready and no documents are in the queue, attempt to print the Windows test page. If not successful, verify the selected port. If USB is the selected port follow step 4. If USB is not selected,change the port to USB, then attempt to print the Windows test page. If not successful proceed to step 4.
4. Turn the printer OFF.
5. Close any open programs.
6. Click Start, Run, type: control printers
7. Right click Printer, left click Cancel All Documents (if available). Confirm if necessary (click OK).
8. Right click Printer, left click Delete. Confirm if necessary (click OK).
9. Left click File menu, left click Server Properties, left click Driver tab, left click print model name, left click Remove button, click Confirm.
10. Close the Print Server Properties window to return Printers and Faxes window.
11. Check that the USB cable is properly connected at both ends.
12. Turn the printer ON.
13. Wait until printer has ready light or green status, watch the Printers and Faxes window to see if printer is automatically reinstalled.
14.a. If printer was automatically reinstalled, right click Printer icon, left click Properties, left click Print Test Page button. If the printer is not automatically reinstalled, call Brother Customer Service at 1-877-Brother (1-877-276-8437).
b. If printer was not automatically reinstalled, try a new USB cable. Ifthe printer still is unable to print, call Brother Customer Service at1-877-Brother (1-877-276-8437).
Nov 02, 2010 | Brother HL-5270DN Laser Printer
How do I turn it on
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
Can not set my hp laserjet 3015 to print postcard stock..
Follow these steps to print on cards: NOTE: Make sure you have the cards loaded in the input tray.
  1. On the File menu in the software program, click Print .
  2. Select the HP All-in-One as the printer.
  3. Open the Properties window. Depending on the program, the button might be called Properties , Options , PrinterSetup , or Printer .
  4. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs. NOTE: Select the appropriate options for the print job by selecting one of the predefined print tasks on the Printing Shortcuts tab. Click the appropriate type of print task in the What do you want to do? list. The default settings for that type of print task are set as summarized on the Printing Shortcuts tab. If necessary, adjust the settings here, or make changes on the other tabs in the Properties window.
  5. Click OK to close the Properties window.
  6. Click Print or OK to begin printing.
Jun 17, 2009 | HP LaserJet 3015 All-In-One Printer
Epson printer won't print
That sounds a lot like the print spooler has suffered some kind of problem...
Try the following:
  • Click START > Run
  • Type "MMC" and click OK
  • Click on the "File" menu then "Add/Remove Snap-in"
  • Click on "Add..."
  • Select the "Services" snap-in and then click "Add"
  • Select "Local Computer" and then click "Finish"
  • Click "Close" and "OK"
  • Select the "Services (Local)" line
Tip: This is the same thing as going to Control Panel > Adminstrative Tools > Services
From here you:
  • locate the "print spooler" service
  • Right click and choose "Restart"
This will restart the print spooler.
If the spooler is the problem you should be able to send a print job to the printer and it should now start printing.
If not then the chances are this is either a port misconfiguration or a driver error in which case you should try:
  • unplugging the printer (leave it unplugged for now)
  • uninstalling the drivers and software for your printer,
  • restarting your computer
  • download the latest drivers from the epson website
  • install these newest drivers (plug in the printer when prompted to do so)
If the port was misconfigured this SHOULD solve the issue but there's no guarantees... If you're still having issues, post again and we'll go from there..
Hope this helps.
Mar 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Printer will not print
Hi Check that the cable is fully into the printer also make sure that there are not any lights on the printer that are on. Within the printer icon right hand click on it and select properties. Once in there select the ports tab at the top of the window and check that the port that is selected is the correct one i.e. LPT1 or USB or which ever the printer is connected to.
Once you have check these try clearing the print que and print a test page from the properties window. If the printer prints ok then there is nothing wrong with the printer and make sure that within the program that you are using the correct printer if not change to the correct one by Ctrl: P and then at the top of the window it should state what printer is to be used.
Hope this works for you
Thanks J
Oct 22, 2007 | HP DeskJet 930c InkJet Printer
Magicard Opera 100 Card Printer Logo
364 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
