Question about Canon XL2 Mini DV Digital Camcorder
Canon XL2 - "Check Lens" light comes on
Client has error message and removing and replacing lens does not rectify.
Before shipping back, there is one routine to try:
1. Turn off. Remove battery pack and internal disk battery (right side, under coin-slot cap)
2. Move main power dial, clicking into each mode on the dial, 3 seconds each. (this discharges residual charge).
3. Twist off lens; make sure pins and contact points aren't blocked. If needed, wipe gently w/soft cloth.
4. Re-attach and reinstall batteries.
5. Cross fingers
If this doesn't fix it, the repair center will have to.
Posted on Mar 26, 2009
Camera still under warranty; client shipped back to Canon. We removed and reattached lens to no avail. Cleaned pins and contacts to no avail.
Posted on Jul 23, 2008
Canon XL2
It sounds like it is placed in transportation mode.
Check your instruction manual as to how to turn it around or pop into a camera shop for advice.
Jan 27, 2018 | Canon XL2 Mini DV Digital Camcorder
I have a Canon EOS, 1000D which I purchased in Feb 09. I have an error message coming up on the screen everytime I take a shot (which doesn't record). The error is a Err 99, "Shooting is not possible. Turn...
I did some digging and found that this error is most often a lens communication error. Are you, by chance using a non-Canon lens?
Try the following:
1. Remove the lens and take a picture without any lens on. If you get an ERR 99, then it is a camera issue and you will need to contact Canon for further troubleshooting or repair (ie. not the lens).
2. If you do not get the error with the lens off, try it with a Canon lens or any other lens. If no error, it is a problem with the original lens.
3. If the error occurs on both lenses, clean the lens contacts both on the lens and the camera (refer to your manual).
Hope this helps.
-Tor
Nov 21, 2009 | Canon Rebel XS / Eos 1000D Digital Camera...
Canon Power Shot A590 IS lens error message won't
Sending it to an authorized cannon repair facility. the lens must be replaced.
Sep 30, 2009 | Canon PowerShot A590 IS Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
Lens wont move
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Canon XL2 Mini DV Digital Camcorder Logo
581 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
