Question about Maytag Washing Machines
How do you install a thrust bearing on maytag model MAV6057AWW
    Genius:
  • 1,028 Answers
Lean washer back remove dust cover remove c clip holding pulley on ..good luck getting back together ..c clip can be difficult due to lack of clearance ..be sure you put bottom washer back on
Posted on Jul 23, 2008
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Replace thrust bearing maytag PAV2300
This link is a picture of the thrust bearing and it's order of how it needs to be replaced. Item number you are looking for is 24.
I hope this helps
Oct 10, 2011 | Maytag PAV2300 Top Load Washer
My Maytag performa washer will not agitate or go into the spin cycle. It makes a loud noise instead
From what you're describing I suspect the thrust bearing needs replaced. The thrust bearing is what releases the brakes. You will not be able to rotate the basket manually with the brakes set. I recommend replacing the thrust bearing kit part number
Jan 10, 2011 | Maytag Washing Machines
I have the MAYTAG top loader washer, Model #MAV6451AWW, it will not spin in the rinse cycle, how to fix / take apart?
Usually when this unit washes but will not spin the thrust bearing kit is damaged.This is easy to repair with little cost.
Completly empty the unit, clothes and water ,unplug the power cord, lie the unit on its back, remove the belt,the c clip from the pully. Take the thrust bearing,the pully the washers off the unit . Grease the new bearing and install new parts. I would also replaced the belt.
Feb 06, 2010 | Washing Machines
Clutch on a maytag
no this machine has a thrust bearing not a clutch if the machine is not spinning well you need to replace the thrust bearing kit it come with a new drive pulley
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV2755AW
All you will need is a 12002213 thrust bearing kit and new belt , the bearing comes with instructions , lay unit on front to do this you schooled not need a transmission
Aug 12, 2017 | Maytag PAV2300 Top Load Washer
Maytag Performa
thinkin your installng a new thrust bearing kit?? new one is different(actually better not as many washers). Laying this unit on its back or even side will alleviate some of that tension your experiencing. My problem is always trying to fit the E-clip back on after installing the pulley. Turnin the pulley i beleive clockwise will engage the brake and give you a little more play in the shaft. i usually get that clip on slightly and then grab and squeeze on with pliers
Mar 12, 2008 | Maytag SAV5710 Top Load Washer
Maytag PAV2000
Its possible that the machine is not reaching full speed during spin. Check to see if the belt is slipping and that the thrust bearing pulley turns freely. When in the spin cycle the thrust bearing compresses the brake directly above it. If this brake is hanging up even a little the machine cannot reach full speed. The diagram on the right shows the thrust bearing assy. and brake.754307c.gif
Jan 14, 2008 | Maytag Performa PAV2200
Will not spin
Ap, start with the tub and basket, make sure there isn't anything caught in between preventing it from spinning. Im assuming you already checked the belt. Next would be heavy duty stuff like the thrust bearing and brake. The brake may not be releasing. You can check this by turning the pulley counter clockwise slowly and seeing if the transmission spins. If not, the thrust bearing and brake may be bad. There was a number of service flashes out on this model concerning the thrust bearing, transmission and seal kit, vibration in spin and snubber kit. These things may be covered under warranty. In the event it's your transmission, it has a 5 year warranty on it....Catriver..post back.
Sep 11, 2006 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
