Question about Acer TravelMate 2300 Notebook
Battery my laptop wont charge at all, i replce already my battery and charger too but still not work, my battery indicator is not blingking.....
    Genius:
  • 2,028 Answers
The only other device that will cause this is the power management chip on the motherboard. Since you've replaced the battery and charger, that rules the simple fixes out. You will need to take it in for a professional diagnostic to see if it's a replaceable component that works in conjunction with the pm chip or the pm chip itself. The pm chip is integrated into the motherboard, so, if the pm chip has failed, you will have to replace the motherboard in order to fix the problem.
Posted on Jul 22, 2008
My toshiba satilite L305D-S5940 Wont charge has new battery new power cord It comes on acts like its going to work then shuts off and sometimes wont come on What could it be please
1st : you can check from the power cable charge
2nd : check the adaptor charger if there is a light indicator or not, or you can check with multimeter to check the voltage on charger adaptor, does show the proper voltage for your laptop, you can check at the end of the connection that leads to the laptop.
note : Remember use DC current at Multimeter
3rd : if the adaptor running well, just plug on the adaptor charger to the laptop, dont turn on the laptop power, just see the light indicator with battery / lightning image on laptop, its explained that there is or is not the power current running to the laptop.
3rd.A : if its no power goes to the laptop then your adaptor charger is failed
3rd.B : if is there, there must be a problem with your motherboard, section power / power plugs, why do not want to charge with a new battery.
Conclusion :
- if the problem on number 1 & 2, then you can change the power cord and the adaptor charger.
- if there is problem on the 3rd.B then you can go to the toshiba services center for your problem.
thats all, hope its help.
Dec 01, 2015 | Toshiba Computers & Internet
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
I already replaced my charger once. This is the second time it just wont charge my laptop and it hasn't even been a year since I replaced the last one. What is wrong?
guess the problem is with your laptop battery....chargers normaly dont crack soon.....
charging the battery....is not OK
to sort out the issue
do this...
1 remove the battery from the battery bay....(hope u know how to do that)
2 now connect the adaptor and check if the notebook works....(without the battery in the bay)
3 now remove the adpator and install the battery...check if it now works with just the battery....
4 now connect the adpator to notrbook with the battery in it's bay...start the notebook.....and let it work for some 3 - 5 hrs
5 remove the adaptor...check if the battery immediatly takes over...if not then battery is the issue
Feb 17, 2011 | Compaq Presario CQ60215DX Laptop Charger...
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Gps wont turn on without it being connected to chargers
This means that the internal battery of the gps system is completely dead and can not hold a charge. All you will need to do is replace the battery and it should work like new. The battery is fairly cheap to buy and replace.
Jul 01, 2009 | Magellan Maestro Elite 4370 GPS Receiver
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
