Question about HP DeskJet 1220c InkJet Printer
Won't switch on.
My printer won't switch on at all. I have checked the fuse and supply, all OK. Did it a couple of weeks ago, and suddenly switched on after several minutes.
  • jazzdownunde Oct 01, 2008
    Haven't used mine for a while. Get a brief flash of green when hitting the on-off switch, but won't switch on. Is the switch itself had it?
Your expert reckoned it was definitely the mains cable, but in fact I bought a new one, still no luck, and the machine has definitely died it final death. I am buying a new A3 printer (some expense!).
Thanks anyway.
Posted on Jul 23, 2008
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
see this causes and fix it. God bless you
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
Brake lights won't work on 93 Subaru impreza. Fuse ok, bulbs ok. Brake light switch replaced 1 yr ago
Mr. Williams since you tried with fuse,bulbs and brake light switch with no success,why you do not try to check your circuit by using a tester and see whether you have any broken wire or bad earth?
Aug 16, 2012 | 1993 Subaru Impreza
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
I have a Maytag PYE2200AYW electric dryer. we had problems a few weeks ago and discovered that the blower wheel was cracked, so we replaced it (part # 31001317). Then a couple days later it just stops and...
Check the thermal fuse and thermostats again to eliminate them as suspects. Both should be zero ohms at room temperature. If you eyed the entire duct system from lint filter to outside of the house for lint, then these are probably OK.
One thing that will shut down a dryer: a defective door switch. If you turn the timer on with the door shut and can hear or see it progressing (running) then the door switch is OK.
If your door switch is operating marginally, the heat can expand the body of the switch and open the circuit (and shut the dryer off until it cools). Check the switch with an ohmmeter with the dryer disconnected from power.
A loose spade terminal on this switch (or anywhere else) can do this too.
Also, a misaligned door or defective door clasp might do this after heating up.
Keep thinking 'heat expands' and you might find it.
The only other thing left is a defective timer.
Good luck from Detroit, MI.
Jun 11, 2011 | Maytag PYE2200 Dryer
Panasonic 1200btu air conditioner
you must check the fuse of pc board.its a glass fuse and propably had burned,replace it,if the fuse is ok then is the varistor and you must get an expert to fix it.
Oct 01, 2008 | Panasonic CW-C60RU Air Conditioner
HP DeskJet 1220c InkJet Printer Logo
104 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
