Question about Epson Stylus CX7800 All-In-One InkJet Printer
Paper jam I have a CX7800, not under warranty. When I lift both the covers up as if I were going to change ink cartridges, I can see the sheet of paper all wadded up but I can't pull it out. I can send a jpg if that would help. This has never happened before. How can I get this out?
Actually, I called my husband, who has much stronger hands than I do. He pulled the wadded-up paper out, then as many little bits as he could see, then we turned the printer back on and ran a copy of something, which shoved the remaining little pieces out. So we re OK now, but thank you for your offer!
Kay Smith
Posted on Jul 23, 2008
My HP5200 13.20.00 Paper Jam
sounds like your fuser sensor or the fuser is bad
Jul 28, 2017 | HP LaserJet 5200 Printer
How do i change ink cartrige in a conon mp250
turn on your printer, pull out the bond paper tray infront of the printer. then lift up the cover of the scanner..you will see that you can lift up the glass cover aswell,after that you will see under a blue bar on the right side where you can use as a support while changing the cartridge then you will see the cartridge below that on the left side, there are 2 ink cartridge there, one for blue and one for colored..
Dec 03, 2011 | Lexmark X1240 All-In-One InkJet Printer
Sheets of paper have stuck under the ink cartridge on the printer. It is not operating now.\ How can I remove the paper?
Hello.
Depending on the model of printer will depend on the removal. If the printer takes two cartridges pulling them up and back should remove them.
If it takes a cartridge for each colour, remove each ink tank, then lift the leaver on the side of the tank holder inside the printer. the print head should be able to be lifted out and the paper should slide out easily.
I hope this helps Regards GM
May 27, 2011 | Canon Office Equipment & Supplies
Changing the ink cartridges?
I have an epson (2 of them). I have to raise the lid and then hold in on the color button for about 6 seconds. Yours should work similar to mine.
Jul 23, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Epson CX7800 3 in one printer feeds mulltiple sheets.
This is usually caused by a dirty or dented feed roller.
The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
All in one printer still under warranty
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Jul 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
