Question about Apple iPhone Smartphone
No Wi-Fi I have a problem with my iphone, i jailbreak it and now it says no wi-fi and wi-fi field is grey and disabled. Also a message appears as "repair needed" and "iphone can not make or receive calls"
  • 2 more comments
  • dirwishm Oct 01, 2008
    Same problem I've been looking for a solution for ever but no luck. That is not true though that jailbraking your phone disables the wifi feature that Care agent has no clue what we're talking about.
  • Anonymous Oct 07, 2008
    i have no wifi, i unlock the iphone with ziphone and i cant fixit
  • Anonymous Feb 05, 2009
    i been looking for a solution, can anybody help me fix the no wi-fi problem?
    or knows a website that can help,i'll gladly appreciated.
  • Anonymous Apr 08, 2009
    I have the same problem! i just got my phone and it just cannot get on to ANY wifi hotspots!
Well since you jailbraked your iPhone you can not use wi-fi because jailbreak disables that future what you can do is restore your iPhone to factory settings.
Thank You, Apple Care Technical Support Stacy R.
Posted on Jul 23, 2008
  • Robert Apr 07, 2013
    Stacy I doubt your legitimacy as an 'apple care technical support'
Tip
How to Fix iPhone 6/6 Plus Show WiFi Problems
"Anyone experiencing really slow WiFi on their new iPhone 6 Plus? Mine is super slow. When I switch off WiFi, LTE works perfectly and very snappy. I didn't have any issues with my 5s and not having issues with my iPad Air. I doubt it's an iOS 8 issue because the 5s and iPad Air are running iOS 8. WiFi also works fine on my 13" MacBook Pro Retina. It's not a router issue. Any ideas??" asked by Mikef91 on the Apple's office discussions.
As one of the leading wholesale cell phone parts supplier online, DBXStore find some solution for you to fix the show wifi problem on your iphone 6/ 6 plus.
Greyed-out, slow or no Wi-Fi signal at all are among the top three biggest Wi-Fi headaches. Even though the iPhone 6 and iPhone 6 Plus came with iOS 8, Wi-Fi problems are still not completely avoidable. Before searching for solutions to Wi-Fi related problems, always update your device to the newest version of iOS. If that doesn't work, then it is time to dig deeper.
1. Reset Network Settings
Settings > General > Reset > Reset Network Settings.
This is a solution suggested by Apple Service. Resetting your network settings including Bluetooth pairing records, Wi-Fi passwords, VPNs, and APN settings; which flushes cache and clears DHCP settings and other networking related information.
2. Disable Wifi Network Services
Settings > Privacy > Location Services > System Services.
This only relates to your location being used for network and not the Wi-Fi itself.
3. Switch DNS To Google
Often times, if your ISPs DNS servers are having problems, you can switch to Google DNS by going to Settings > Wi-Fi then tap the "i" icon next to your router, scroll down to DNS and tap the numbers, then enter "8.8.8.8". Restart your device and check if it works.
4. Change The Routers Broadcasting Band
Change the routers Wi-Fi broadcast from an N network to a G network, or from 2.4GHz to 5GHz - this depends on your individual router hardware.
5. Factory Reset
Settings > General > Reset > Erase all Content and Settings > Erase iPhone.
Last but not least, restore your iPhone and set it up as a new device.
Other tricks like placing the iPhone 6/6 Plus in a refrigerator, freezer it for 15 minutes, or the opposite using a hair dryer to heat up the device might also be of help.
However, if all these software related tricks don't help, it could possibly be a hardware problem with the Wi-Fi antenna. Then the only fix is to replace your antenna with a new Wi-Fi antenna replacement. Here are links to the parts and tutorial guides' for reference.
on Jul 23, 2015 | Apple iPhone 6
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Can't get my Altec backbeat 903 headset to sync with my itouch
Try updating your Ipod touch to the latest OS. I have read that older versions of the Operating system didnt offer bluetooth capeability, or it wasnt very stable. If you have the latest update then try this:
First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
One On the device, tap Settings > General > Reset > Reset Network Settings. Check to see if the device now displays the Wi-Fi address or Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and a Bluetooh address, then you're done with these steps and you can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step two.
Two On the device, tap Settings > General > Reset > Erase All Content and Settings. Check to see if the device now displays the Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and Bluetooth address, then you're done with these steps and can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step three.
Three
  1. Restore the iPhone or iPod touch software (this erases all data on the device) using iTunes (see article 305744 for additional assistance).
  2. After the restore is complete, sync your previous settings (mail settings, text messages, notes, call history, contact favorites, and so on).
  3. Now see if your device shows a Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth).
If there is a Wi-Fi address and Bluetooth address, then you're done with these steps. If there is no Wi-Fi address or Bluetooth address, then continue to step four.
Four If there is no Wi-Fi address or Bluetooth address listed after doing the above steps, then your iPhone or iPod touch may need to be repaired. See the iPhone Service FAQ or iPod Service FAQ for additional service information.
Note: If the device shows an address in the Wi-Fi Address field and you are still having issues using Wi-Fi, refer to article 305715 for additional Wi-Fi troubleshooting tips. If the device shows an address in the Bluetooth field and you are still having issues using Bluetooth, refer to articles HT1843 and HT1664 for additional Bluetooth troubleshooting tips.
hope it helps!
Jun 24, 2010 | Altec Lansing BackBeat 903 Consumer...
My Iphone wifi button is grey out
Resolution First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
If there's still no Wi-Fi dddress or Bluetooth address, then continue to step three.
Three
Nov 08, 2009 | Apple Computers & Internet
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Apple iPhone Smartphone Logo
379 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
