Question about Samsung 793S 17" CRT Monitor
VGA Pin Configuration
I had my computers stolen and the dwax that did simply cut the vga cable. Now I need to solder 2 x 15 Pin Connector to the cables in order to have the monitors operational again. Can you please assist me with the correct pin lay-out and colour coding to be able to do this.
Thanx
Hennie
e-mail: hennievds@yahoo.com
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Posted on Dec 24, 2008
  • 558 Answers
Http://www.acl.co.uk/pinouts.htm
Posted on Jul 22, 2008
Hi first u check the cable modul and buy a new cable to installistion
Posted on Jul 20, 2009
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Jun 03, 2010 | Envision H170L Monitor
VGA problem with HP monitor
The VGA cable are standard pin out for VGA DB15HD connector.
Learn about it here: http://en.wikipedia.org/wiki/VGA_connector
Apr 02, 2010 | Computers & Internet
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
Packard bel slimview 517, twisted vga cable
yes if you can solder then cut the cable and solder the 15 pin vga connecter first test the continuty between the connecter and opposite end write it on paper then according to that solder all wires but better to buy new cable for long time
Oct 28, 2008 | Computers & Internet
13pins "from the inside monitor" "to the VGA 15 pins connector
hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Apr 03, 2008 | SAMTRON 55V 15" CRT Monitor
Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Apr 02, 2008 | Computers & Internet
Yellow Monitor
Its not something that anyone can do. you'll need to get a new cable and open the monitor to connect it on the inside. to get the vga connector cable you'll need to make the trip to a repair lab anyway, cause its not the generic kind with pins on both sides that you can get in any general computer store. Hope you work it out, and don't get yourself zapped please ;]
Apr 21, 2006 | SAMTRON 78DF 17" CRT Monitor
Samsung 793S 17" CRT Monitor Logo
2,538 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
