Question about Whirlpool LGB6300 Gas Dryer
Whirlpool dryer - need to light the pilot for the gas
  • nezco1 May 11, 2010
    so.....replace glow bar?
    Genius:
  • 1,028 Answers
No pilot glow bar ignition
Posted on Jul 23, 2008
Dryer hot at first and then stay cold
Sounds like the thermocouple needs replaced. When ever the couple doesn't make enough electricity the gas valve is shut down automatically. Sounds like your thermocouple is right at the threshold of minimum voltage and doesn't generate enough voltage to keep valve open.
If not that try YouTube for some good diagnostic videos:
https://www.youtube.com/results?search_query=Whirlpool+gas+dryer+pilot+light+goes+out+quickly+or+doesn%27t+stay+on
Oct 28, 2015 | Whirlpool Dryers
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
Whirlpool dryer will not ignite.JET FLAME WILL NOT GO ON.
if the ignitor is lighting up, or if you have a actual flame pilot light, depending on the machine, if you have a pilot light, check the thermocouple that the flame from the pilot is supposed to heat , but thats on very very old machines , if you have a glow plug , ( a heat source that comes on electrically and glows , then you need to check the 2 coils that are on the gas valve, they have gone bad
Jul 13, 2011 | Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Whirlpool Dryer LGR6611LQ0 will not heat up
there isn't a pilot you have an electroic ignitor in there part number 279311.there also is a sensor,gas coils and the gas valve,you need a meter to read them out,you said you checked the breaker and cleaned lint out ,is it dead?read out the thermal fuse first part number 3392519 located on blower wheel housing,unplug the dryer before you do anything and pull off one of the wires on thermal fuse then read it out hope this helps
Mar 22, 2009 | Whirlpool LGR6611L Gas Dryer
Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer
Did you check the coils for the gas valve with a meter for ohms resistance?
Aug 09, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGB6300 Gas Dryer Logo
236 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
