Question about Whirlpool Washing Machines
Washing machine my washer will only agitate with only very small loads. the dogs are wore out. what is the most simple way to fix it. i have seen several repair parts for this.
  • 5,911 Answers
If you are talking about a simple issue of the agitator not turning, replacing the agitator dogs would be the simplest and least expensive option to try first. A pack of four of them usually costs about $5. You can find them at Type in your model number and look under the Agitator Parts section. Let me know if you need instructions on how to replace them. Please post your complete model number if you require further assistance. That way I can get a perspective of which agitator type you have.
Posted on Jul 22, 2008
Agitator not working but spinner is fine how can i fix myself?
the dog ears are wore out look at a vid on it type in dog ear re[placement washer perhaps that will lead you to one if you open the washer the center top of the agitator pull off the cap there should be a bolt head down there unscrew it and pull out the top area the dog ears will be there three little plastic thing looking like teardrops with small fins to catch the agitator to move it they are worn out cheap to replace
May 14, 2016 | Washing Machines
Admiral stylemaster 4213343
Before you buy an agitator. Check the dogs that catch and cause the agitation motion. They cost 50 cents a piece and usually there aer five. Go on youtube and look for replacing dogears in washing machine agitator. Idid and thats all it was $1.00 2 dog ears wore out causing the agitator to slip. It took 30 min to fix. Hope this helps. The dogears get wore to round and will not hold! Brian Thompson
Sep 03, 2014 | Admiral Washing Machines
Simpson esprit 450 Agitator only turns one way causing load to wrap around agitator. I've removed agitator and nothing is caught up. Wondering?
Inside the agitator there may be a circular section that has 4 small tabs with small teeth on them, if this has these, inspect each tab to see if the teeth are wore, ifr so replace the teeth. They are called "dogs"
Mar 31, 2012 | Washing Machines
Whirlpool washer agitator not working
You most likely need to replace the dogs in the agitator, two piece agitator design. It should spin one way and catch the other on the teeth of the dogs. It will spin freely either way when the dogs are wore out. This is for the top half of the agitator, bottom is fitted to transmission shaft. You pop the top cover, remove the 7/16 bolt and both halves together to change dogs of agitator. Pull halves apart to change dogs. Fairly simple.
Jul 31, 2011 | Whirlpool Washing Machines
Does not agiteate.,spins freely
You have a two piece agitator held onto the top of the transmission shaft by a 7/16 inch bolt which turns off counter clockwise . Pop off the top of the agitator cover with a screwdriver in the slot to see it. Remove the bolt and pull out the entire agitator. There are four little dogs in the middle of the agitator that the teeth are wore off, these need to be replaced, you pull the agitator apart to do this, or find a service store and take it there. It is very simple.
Jan 20, 2010 | Roper RAS8445KQ Top Load Washer
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loading washer model LA8800xtn agitator dogs stripped. How do I fix?
The following link explains how to change agitator dogs:
This is very simple and inexpensive repair. Read through the link provided and let me know if you have any questions. I hope this helps you.
Jul 07, 2009 | Washing Machines
Whirlpool Toploader won't spin with a heavy load.
Do you mean it won't spin or won't agitate? Agitate means that the post in the middle (agitator) turns back and forth. It is very common for the agitator to stop working properly, especially if you normally do large loads.
Inside the agitator are little nylon feet called dogs. They grip the inside of the agitator and work like a centrifugal clutch, and they wear out every couple of years. They are normally the reason the machine won't agitate. I have had my washer for less than 4 years and I just replaced the dogs for the second time.
If you are handy with some simple tools, you can probably do this. If not, it should not cost too much to repair, and will be even cheaper if you remove the agitator and bring it with you to the repair shop. They did not even charge me the first time the dogs went because it took about 10 minutes to fix and I brought the agitator to them.
To replace the dogs, go to your local repair shop and tell them you need a set of agitator dogs for your washer. I paid $10 for them.
Pull off the fabric softener dispenser top and assembley. It just pulls out. There is a plastic disk with a handle on it. Pull this out and you will see a bolt. I believe it is an 11mm. You will need a couple of extensions to reach it. Remove this bolt by turning counter clockwise and the agitator will pick strait up. Place the agitator on the floor and press down on the base with your feet. If you look down into the agitator you will will see four small holes in a circular pattern. These holes have small plastic prongs coming through them. Using a screwdriver, gently press down on these prongs one at a time while pulling up (gently) on the agitator. This will release the agitator post from the base.
From the underside of the agitator post you can see the dog assembly. It pulls out easily. Pay close attention to how the dogs come out and put the replacements back in the same way. I repeat, PAY ATTENTION. It is a simple assembly process, but if you don't watch closely how it comes apart you may have a hard time putting it back together.
When you finish replacing the dogs, place the top of the agitator back on the base. Line up the pastic tabs with the holes (that you removed using the screwdriver) and carefully press down until the tabs snap through. If the tabs are not lined up with the holes, they will break off and that will be bad.
Place the agitator back in the washer, bolt it down, replace the plastic cover and fabric softener dispenser. It should be good to go. Do a trial run without clothes. Just push down on the top of agitator while it is in the agitation cycle. It should agitate correctly now.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Top agitator doesnot work
Your agitator dogs are worn out. They are 4 small pieces in the agitator that act as one way clutches. They allow the top section to turn one way but catch the other way. Pretty simple fix.
If you will post the complete model number I will find the part numbers for you and try to provide instructions on replacing them.
Nov 26, 2007 | Whirlpool LSB6200PQ Top Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
