Question about Acoustic Solutions Audio Players & Recorders
Faulty USB device
I have a Sigma Tel MSCN USB Device with storage size 1GB. Written at the back of this device is Acoustic solutions, Model no: 513/3848. it is an mp3 player. Its output sound is not clear, some audios wldnt play but would do when played from the computer system so I need help. Could you please send the factory settings to my box
SOURCE: MP3 Player with SigmaTel MSCN chip
Hah hah.. You are about to track down firmware for it and flash it, right? Bad idea! Instead, put a hook end on the end of a safety pin, gently get into the earphone jack, and coax the contact springs back to where they seat well against the earphone plug..
BTW.. this fix works with real ipods too
Posted on Feb 07, 2008
  • 38 Answers
Hi mike,
The television has audio out with two pins red and white. This can be connected to the input of subwoofer. and dvd player should have analogue 5.1 out put i.e six pins this can be connected to the subwoofer, but only either of can be used at a time.
Posted on Jun 08, 2008
  • 53 Answers
SOURCE: No sound from one speaker
techs are correct. sorry.
what type of TV are you using?
if it can be firmware upgraded via USB connection. that might do the trick.
Posted on Jun 24, 2008
  • 151 Answers
SOURCE: i cant rig up my surround sound to my tv
Run a phono cable from the tv output to a input on your system,select this input and you should have sound,if not go to tv menu for sound set up as some tv,s need the output turned up or even to be switched on.
hope this helps.
Posted on Jul 02, 2008
  • 23 Answers
SOURCE: please help?
Make sure your audio properties are set to the correct output. If you have a second sound card, this is the most common problem. On older systems, the PCI sound card takes over as your primary source of sound output and input, therefore your onboard sound is useless. If neither of these solutions help, it might be a problem with yoru speakers and in that case you will want to check to make sure they are working properly. If this does not work, go into your BIOS(assuming you are using onboard audio) and make sure your audio device is enabled, however this is unlikly beucase it would probably cause problems with windows media player when trying to play any audio. Lastly, there is always the chance that the audio is simply malfunctioning and windows media player, nor the rest of your computer realizes it.
Posted on Jul 03, 2009
Cannot download 1GB video file
If your photos and videos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 29, 2012 | Canon PowerShot SX100 IS Digital Camera
I have black jack..and wen ever i insert my 1gb micro sd,,it shows storage card not found,,,,so,can you just tel me the way to solve this issue....
try inserting a different micro sd card of 1gb in your mobile, if it gets work, then you could be sure that their is a fault in your that memory card which shows storage device not found.
it may got currupt.
or try formatting that memory card through a computer, then insert it..
it may will work, but if not then its time to buy a new memory card as that card is currupt.
Aug 18, 2011 | Samsung Blackjack SGH-I607 Smartphone
Xbox 360 system will not reade any kind of storage format, like hard drive or flash drive in the usb slot.
If you have the Spring 2010 console update installed on your 360 console, you have to configure the USB device it before it is recognized by your Xbox 360 console. Connect your device, go to My Xbox menu, go to System Settings, then choose Memory. From here, select "USB Storage Device", and choose "Configure Now".
Your device will need at least 1GB free storage, and your console can use 16GB maximum of all attached USB storage devices total. Move the slider to configure the space to use & press the A button to set. Your USB device should be listed as a storage memory unit now!
May 09, 2010 | Microsoft Xbox 360 Console
Internal microphone not working
I have Dell Inspiron 1520 and I have issue to built in microphone is not working. I tried to execute the Sigma Tel driver from Dell Driver and Support website but prompted 'Exit Error; Error : Device Object not present, Restart system and run setup. Then, asked Dell support to help and they are not really helpful, after System Restore and drivers upload and finally asked to reformat the laptop........
Anyway, this is what works for me.
1) Download the Sigma Tel driver from Dell Support Drivers page and save it in Desktop
2) Shutdown your computer
3) Start your computer and press F8 at the Dell Logo page
4) Select Safe Mode (not others)
5) Proceed to work on Safe Mode
6) Right-click the Sound icon and activate the Sound icon
7) Select Recording device.
8) If still not working, then execute the Sigma Tel driver that saved in desktop
then, shutdown the computer and start as normal, you may see the system able to detect the built in Microphone then.
Hope it will work the same for you too..!!
Apr 20, 2010 | Dell Latitude E6400 Notebook
Can I replace sigma tel audio device on my laptop by soundmax digital audio device?
NO, it is built into the MotherBoard. The best you would be able to do, would be a USB, device.
Apr 14, 2010 | Dell Latitude XFR D630 Notebook
My pc is not recognizing my sansa mp3 player clip model 1GB. Do I
Here is the manipulation to be done to remedy this.
To begin, open Windows Explorer and click the Tools /Folder Options /Display. Look in the list "Hidden files and folders" and check "Show hidden files and folders."
  • Right click on the icon "My Computer" from desktop and then click Properties. Then click on Hardware then Device Manager.
  • Right click on the line marked "Unknown Device" and click "Update Driver".
  • Then in the wizard to update the hardware choose "No, not this time."
  • Click "Next."
  • Select "Install from a list or specific location (Advanced)".
  • Click Next.
  • Then click on "Do not search I will choose the driver to install".
  • Choose from the list of hardware USB hub.
  • Click Next.
  • Click on "Disk".
  • A window opens. Then click "Browse", go to C: /windows/inf and select usbstor.inf and click Open.
  • The path of the selected driver will appear in the previous window. Click "OK". The driver will be installrd and you have a line called "Device USB Mass Storage".
  • Choose from the list of hardware "Storage Volume".
  • Click "Next."
  • Click on "Disk".
  • A window opens. Click "Browse", go to C: /windows/ inf and select volsnap.inf select and click "Open."
  • Then the path of the selected driver will appear in the previous window. Click "OK". The driver will be installed and you have a line called "Generic Volume".
Jan 11, 2010 | SanDisk Sansa Clip MP3 Player
Annoying audio driver problem in Dell Laptop
you have done all there is to try to correct the problem, I would say its somethinhg you have to live with, you might try changing the headset and mic if your using one to see if that helps, but other than what you have done there's not much more you can do.
Jun 27, 2009 | Dell Inspiron 630M Notebook
USB Ports don't recognize typical thumb drive, mass storage devices
I'm not completely sure, but this may be a result of faulty drivers.
Try googling the brand name and the word: "Driver"; along with any other details about the device. (Model No. et cetera.)
Jul 31, 2008 | Computers & Internet
How can i download themes for my mobile
connect the data cable to usb port and using mass storage option in your mobile ,you can connect it to the pc.but without any memory card it is not possible.
Jul 01, 2008 | Handmark Software MobileLists (950142) for...
50 people viewed this question
Top Acoustic Solutions Audio Players & Recorders Experts
Are you an Acoustic Solutions Audio Player and Recorder Expert? Answer questions, earn points and help others
