Question about Sony Playstation 3 (PS3) Console
Multiple HDMI Sources.
I want to connect both my hd dtv box and ps3 to my tv using HDMI, but my tv only has one HDMI port. Are there adapters that can used, or would that compromise the quality of the video?
  • ksmoov Jul 23, 2008
    Thanks Agent Aaron!
    I'll look in to it.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey ksmoov,
Adaptors do exist that allow you to connect two devices to the same HDMI port, but keep in mind that as with all adaptors and switches, some signal degradation may occur. The extent of signal degradation encountered does vary from product to product, so I'd suggest using an online search engine to look for reviews on various "HDMI 2-in-1-out" switches and choose the one that you think looks the most reliable.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 22, 2008
How do I start watching Netflix on my hitachi smart TV
Open the Netflix app and sign in to your account!
Dec 24, 2016 | Netflix
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
Mar 05, 2016 | Vizio E370VL 37 in. LCD HDTV
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
How do I connect a Cable box and Blueray player if my TV only has one HDMI connection on the TV?
Not sure how good they work but I have seen plug in adapters which split a single HDMI input to a two unit input. Like we used on older computers to gain additional USB ports.
Apr 03, 2012 | Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I need to know how to switch the TV to 1080. I'm trying to use a HD box
Connect you hd cable box to the hdmi input. If you don't have an hdmi input and have a DTV input you can get an HDMI to DTV adaptor. I hope this helps.
Mar 20, 2011 | Philips 60PP9202 60" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
