i enabled a password on the ipaq then forgot it. it asked if i wanted a hard reset i clicked yes. later it just wont power on. i removed the battery and all but now it dosent even charge when its on the cradle. please help.
To do a full reset, you hold the calendar and itask buttons (buttons 1
and 4) down at the same time, then insert the stylus into the little
hole on the bottom and press gently. Hold all for 4 seconds. The screen
should begin to fade. Now release all. If successful, you will not be
able to start the machine by pressing the on button. You will have to
reconnect to ac power to start it.
I just bought a used unit but it wont power on an my computer doesnt recognize it, what should i do?...
(More)
I just bought a used unit but it wont power on an my computer doesnt recognize it, what should i do? I did not receive any software with the unit just the usb cables and a docking station that plugs into an electrical outlet.
Seems to be cold solder issue, my h5550 will start to work properly if I leave it on for a couple of...
(More)
Seems to be cold solder issue, my h5550 will start to work properly if I leave it on for a couple of hours. But If I ever let it cool down, It will fail to light up all the way until it gets good and warm.
HP Ipaq H5550. I got Hp IPAQ h5550 from USA. Now i am in india but unable to use the indian sim (as...
(More)
HP Ipaq H5550. I got Hp IPAQ h5550 from USA. Now i am in india but unable to use the indian sim (as there is sim slot given in the hand set )with this handset. No msg get displayed when the sim is inserted.
i cant see then bottom of my screen, starts up fine then for some reason the screen just goes hey...
(More)
i cant see then bottom of my screen, starts up fine then for some reason the screen just goes hey wire and when it finally does come right the bottom half of the screen is grey
