Question about Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT Burner
Copying CDs I have figured out how to select which tracks I want to copy from a CD. How do I then select tracks from another CD and when I have completed all of these steps, go on to copy the selected tracks?
Trial and error, pushing buttons until I was able to do what I was trying to accomplish. I would suggest more detailed instructions in your manual.
Posted on Jul 23, 2008
How do you import CDs into iTunes?
Copy music from a CD to iTunes by following these steps:
  1. Insert a music CD into your computer. Notice that iTunes opens automatically.
  2. In the list that appears, use the checkboxes to select or deselect the songs you want to import. Songs that are selected will be imported.
  3. After you've selected the songs you want to import, click the Import button. iTunes will begin copying the music from your CD to your iTunes music library.
  4. After the songs are imported, click the Eject Disk button.
  5. Select Library in the Source list to view all the music in your iTunes library, including the songs you just imported.
Of course, if you want to import CD to iPhone, you can also read this guide. How to Import CD to iPhone
Oct 08, 2015 | Audio Players & Recorders
Vinpower Digital Vinpower Digital Burner- manual
Please explain what this term means: "copying audio tracks from computer memory". In normal operating you don't copy audio tracks you burn them to the disk using a compatible burning software.
May 15, 2014 | Vinpower Digital Computers & Internet
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Not completely copying CDs
This one is a bit difficult to solve via this interface. Please, feel free to contact us @ 877-686-8868 x208 for technical support and one of our representatives will be glad to assist you. Thank you for purchasing EZ Dupe Products.
Sincerely,
EZ Dupe Technical Support
Jun 01, 2010 | EZ Dupe 3 Target 16x DVD Duplicator...
I have been trying to copy some CDs onto a new MP3 player. It will copy some, but with others I get the message "unsupported media type". Even when copying a whole album, the message will come up with some...
Are they burned cds? and did you download some? if so your player my not accepet wma or other types of files check in hand book if you can change settings on player
Nov 10, 2009 | Memorex MMP8567 MP3 Player
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Copying CDs to MP3
You need to edit the tag information before you transfer them to the MP3 player.
You can right click on the track and select rename or, Properties>Summary Tab and then make the changes then transfer to the device.
If you are using Windows Media Player to RIP the tracks, there is an option to "GET CD INFO" from the internet to save you a few steps.
Best of Luck.
Nov 01, 2007 | Audio Players & Recorders
Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT Burner Logo
126 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
