Question about GE Energy Star WCVH6260F Front Load Washer
Not agitating or spinning
We had a power failure last week and since the washer is not working correctly. At first it just didn't seem to be spinning correctly, now it isn't even agitating during the wash cycle. The clothes just sit there while water pours in and drains out. I have cleaned out the drain filter, checked all hoses, reset the machine(turned off circuit breaker for 30sec)and it still isn't working. Any suggestions? I assume the power failure fried something, was wondering if anyone knew what it may be so I can replace it.
  • ornn Jul 29, 2008
    washing machine will not spin out cloth
You may have read about the "filter" at the bottom front of the washer, behind the lower panel (held on by 3 screws)...
Just go ahead and open it up, ( I used a large baking pan to catch the water) and then you will be AMAZED at the amount of lint, tape, coins, rocks, etc - that are stuck in there!
Clean it out, and then put it back in - in the correct alignment - and do a new load of wash.
I think it is the main problem for many of the related postings.
Good luck.
Posted on Oct 03, 2008
I also read somewhere to leave unplugged 48 hours.
Posted on Sep 08, 2008
Have the same problem. Did everything, cleaned the drains, unplugged and let the memory erase, even did the trouble shooting cycle. Got an error indicating hoses were plugged but it was an old code and after clearing it, didn't get it again. So frusterating. After only 1.5 years, is something wrong with the motor?
Posted on Aug 19, 2008
    Genius:
  • 1,028 Answers
May try leaving breaker off 10-15 min 10 secs is too short of time for power to drain
Posted on Jul 23, 2008
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
GE WASHER WJSR4160GWW Won't Agitate
Sounds like tub belt failure. Check online for model layout. If unit is belt driven, remove back panel to access internal works. Look for broken belt. Depending on setup, control system stuck on water pump. Else possible control panel failure or motor (if water pump separate).
Jul 10, 2009 | Washing Machines
Ge WASE4220A0ww will not drain or spin
hI!!! You seem to have a bad transmission or a bad motor they are all expensive to repair..Good luck..
Jan 03, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not agitate on wash cycle
could be a belt (doubtful) or it could be the connector underneath the. if the bolt isn't tight, it could be sliding along the cutout that makes the agitator work. tip forward and check it from beneath/backside whicheverr has the easiest access to view the connections.
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
171 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
