Question about Samsung RS2630SH Side by Side Refrigerator
My Samsung side by side is not working on the Fridge side
It should read 4 degrees C and is running at 16 degrees, I have checked the fan which seems to be working fine, do you have any idea what's wrong ?
Ended up calling Samsung Customer Service, they are arranging a local engineer to call. I'll let you know how it goes.
Posted on Jul 23, 2008
Freezer 8 degrees, fridge 48 degrees. Fridge fan was replaced and worked ok for a month.
Sounds like both are about 8 degrees over optimum, if your thermometer is accurate. Can your freezer keep ice cream hard?
Usually, one control affects the temps of both chambers, and the other affects the balance between them. Your balance seems ok, so if you're unable to set it to run longer/colder overall, and your ice cream is not firm/hard, this could indicate a more serious problem. Airflow is important, so you should avoid loading in such a manner that restricts airflow within either side, and verify that fans run when door switches are actuated.
May 18, 2011 | Samsung RS265LABP Side by Side...
I have a GE mdl PSI23SGRCSV side by side. initially the digital temp displays for both freezer and fridge sides went to 16 on freezer side and 43 on fridge side. This happened almost overnight it seemed....
it may be that your fridge is now low on freon the techs now do not know what to do the best thing to do is to call the tech and ask them to test the compressor pressures and see if it is low on charge. unless you know how to take the lower back panel off (the one that is probably cardboard) and feel the lines on the compressor and see if it is really cold and really hot that means that it is cooling properly but if it feels a little warm cominv out of the cooling side and hot on the return side then you need more freon.
Mar 04, 2011 | Refrigerators
Freezer works fine air is circulating and temp. is zero degrees refer side is 60 degrees and air does not seem to be circulating. Settings are set on 4 as they have been for five years Do I have to...
Check to see if your hear your evaporator fan is running in your freezer, then check behind the refrigerator and see if your condensor fan is running. Make sure your condensor coils are clean under your fridge. Your symptoms are leaning towards dirty condensor coils. Good luck!
Aug 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Samsung control panel says cold but fridge is warm
have you checked to see if the interior blower fans are working?
I'm not a tech, but it seems to be my problem
Aug 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Mar 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS267LABP Side by side refrigerator
Not sure if you have one or two problems, so need to be systematic. From what you say it seems you have a defrost heater problem.
Here is how I would start:
- Get a service manual for your fridge.
- Make sure you are not running the fridge in "sales" mode
- Run a self test of the unit (as described in the manual).
- Based on results, unplug the fridge and remove cover of the electronic compartment
- Remove the connector of the heater units.
- Measure the resistance of each heater to see if they are all good.
- If this is the case re-plug the connector and plug the fridge
- Using "force mode" described in the manual turn the heaters on and measure voltage on the respective connector.... this will tell you if board and built-in relays are good.
This should give you a good start of where the problem is.
Note than when in force mode you can also force the compressor to run in different modes and measure the related voltages. If the above does not get any hint, then moce your troubleshooting that way.
Mar 20, 2017 | Samsung 26.0 Cu. Ft. Side-by-Side...
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Digital display reads appropriate temperature but Fridge side is warm on the inside.
ok 1 of two problems defrost heater and thermostat
evaporator fans going bad just verify that the fans run if not I've seen on some side by side that the defrost thermostat controls the evaporator fan. jump the wires passing a pin trough the two wires of that defrost thermostat (usually brown/pink or orange/pink) if fan turns on theres go your defective part. the defrost thermostat usually in these model is a L 40 or L 45.
Apr 08, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
RS21DCNS
as a rule of thumb mfgs say give the unit 24 hrs to stablize where are you gettings the readings the fridge or freezer sides freezer readings run from -8 to -10 the fridge should run 34to38
Jan 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
73 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
