Question about Sharp Microwave Ovens
Sharp model R-4A54
Purchased 06/20/04. While operating there was a loud snap and then the unit went totally dead. No clock, no light inside, nothing. Outlet power OK.
  • Sharp Master
  • 9,098 Answers
Chances are your high voltage diode blew or the high voltage capacitor shorted, and your fuse is out too.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
No power, no clock, no light. Dead
you cant do much about this.. the only thing you can do is check if the power is going to the magnetron unit or not.
but i wouldnt suggest you to experiment with the unit as it can cause short circuits.
you should rather go find a cheap electrician
Mar 17, 2014 | Microwave Ovens
follow this next steps, use the VOM, and fix it. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some modelsbcd93e93-ccee-45ab-ba5c-70967b1ff19b.gif
Jun 11, 2013 | Sharp R-1874 Convection/Microwave Oven
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
Microwave JE 1860 has been making a loud noise for several months. Today it quit. Nothing works. No light. Turntable does not turn. Nothing on the display ... not even the clock. The unit was purchased...
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
Jul 01, 2011 | GE JE1860 Microwave Oven
My whirlpool mh3185xps went completely dead. No
sorry but yes its time to replace it,
oh,, by the way,,,
your very lucky to still be alive right now!!!
tinkering inside of a microwave could kill you,,,
inside of your microwave is a very big capacitor it works just like a police stun gun works,,,however it dont just stun you,,,it kills you! witch would realy spoil your day, be warned, many a fool has took a free flying losson from one of them but servived just!
Jan 09, 2010 | Whirlpool MH3185XPS Microwave Oven
The lights went out for my clock, how do I fix
You have a two part board. The control and the display. They're hooked together with a 12 wire connector soldered at each end. You might be able to find a weak solder joint. Check for one that is a little off-color, or you might see a crack if you use a magnifier. If so reheat with a gun. Otherwise forget it, the board, if available, would cost more than a new unit.
TWO ANDS. And know what you're getting into before you take the top off. See how to discharge a capacitor on many tech sites. Capacitors have killed people!!! The second AND, is be sure you stay by your MW while cooking. If you mistakenly enter the wrong cook time, well, fire and like that.
Nov 18, 2009 | Sharp R-319FW Microwave Oven
There is an internal fuse inside. Need to find the cause for it blowing or it will just go again. Check the monitor switch and door switches. Eric
Aug 08, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Microwave Ovens Logo
113 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
