Question about Singer 3116 Simple
Singer Simple.....not really!
I just bought a Singer Simple to make some easy projects. Within 2 ft of stitches the machine locked up and the bottom bobbin thread is gobbed up and won't let loose. I tried several times to fix the problem. I cleared the thread, checked the case for placement several times, adjusted the bottom bobbin thread. Nothing! I have used an entire bobbin of thread and nothing to show for it. I am SO frustrated!!! Could you please help me resolve this? I don't think this Singer is Simple!
  • thecarverfam Nov 16, 2008
    The bobbin is a jumbled mess for me too! I hemmed two pair of pants and got one leg done on a pair and now it is messing up! I've redone it at least 10 times. What makes the bobbin jumble up like that?
    Genius:
  • 1,788 Answers
You really should go on the Singer website and look up support and frequently asked questions. If, you cannot find your manual they have it there to download for free. I really think that you are not threading the machine right, check it with the presser foot up and the thread should feed freely, then lower the presser foot and it should not feed at all or very little. Most of the bunching of thread underneath is the fault of the top thread not the bobbin. Make sure you turn the handwheel towards you never away from you. Also, check your needle, inserted flat side away from you and, if it were me, I would use a new needle before I sewed again, This machine comes with a dvd, try watching it.
Posted on Aug 27, 2010
I have a singer 201k sews fabric perfectly but I wanted to do some leather I bought a walking foot attachment leather needles and heavy duty thread but the machine is not stitching properly very tiny...
Sounds like it is still not feeding smoothly, Try putting some clear tape on the bottom of the foot and tissue paper under the leather. Leather is tricky sometimes.
May 31, 2014 | Singer Sewing Machines
My stitches are to loose
Generally loose stitches often means you forgot to lower the presser foot. It's really easy to forget when you are sewing thicker fabrics.
Barring that it sounds like your tensions need to be adjusted. Try to remember "loops on bottom... tighten top tensions" "Loops on top, loosen top tension."
Oct 01, 2013 | Singer 8763 Curvy
I have a Singer
Which stitch are you using?
To check thread tension for straight stitches, use different colors of thread in your top thread and bobbin. If the top thread shows on the bottom of the fabric, turn the dial counter-clockwise (towards a lower number). If the bottom thread shows on the top, turn the dial clockwise. Do not adjust the tension too much (for example, go from 2 to 2.5 if increasing the tension) at a time; test another set of stitches. Alternatively, you can adjust the bobbin tension in the reverse directions. However, it's very easy to damage the set screw in the bobbin case so do this as a last resort. Since this is a vertical bobbin case, put the bobbin in and hold onto the thread. If the thread moves when you dangle the bobbin case, tighten the screw. Loosen the screw if the thread doesn't pull out of the bobbin when you hold the unit.
For zig-zag decorative stitches lower the tension until the puckering stops. Usually the top thread will show on the bottom of the fabric.
If the tension is not changing when you turn the dial, make sure that the presser foot is down. The sewing machine may need repair. The tension mechanism depends on a spring and that can break. See the Singer site for a parts breakdown and contact your Singer dealer for the parts.
If the top and bottom fabric are not moving at the same rate, you can get a different type of puckering. You may want to get an even feed foot if there are several layers of fabric.
The manual for the 3116 is available from Singer: http://www.singerco.com/uploads/download/438_3116.pdf .
I hope this helps.
Dec 08, 2011 | Singer 3116 Simple
My singer simple is missing stitches when ziz zagging? only appears to be on the top
I would try a metal bobbin, SA 156 or a Singer 15j. The SA 156 metal bobbins can be bought really cheap on ebay for $8.99 free shipping and there are 20 in the package. My 3116 sometimes will act up with the plastic bobbins and this cleared it up for me. Hope this helps you. You may be able to find the bobbins local because it is the same one they use in Brother machines but they will cost you more. Good luck
Nov 16, 2010 | Singer 3116 Simple
The Singer touch and Sew model 700 machine I have is working well but it stop pulling the fabric as it sews. I have moved the regulating pressure dial to all the settings but it still not pulling the...
Call Singer at 1-800-4singer and ask Singer's excellent customer service. They can steer you right. One, thing you can try is unthreading your machine completely and rethreading top and bobbin. Check your needle, change if you have had it there for a few projects. Make sure your feed dogs are up and that your stitch length is not set at zero. At least you will have tried all of the easy stuff when you call them. Let me know how you make out, I hope it is really not serious, Good luck
Sep 18, 2010 | Singer 3116 Simple
Bunching at the bottom
Is your bobbin clean and inserted correctly? (counter clockwise) A little fuzz can be a problem. Clean with a q-tip and oil if needed.
Oct 07, 2009 | Singer 3116 Simple
I had to replace a bobbin case because either a design ( I made) was too dense or my thread caught on something and the machine needed to be timed. When I did the test stitching in sew mode it stitched...
Being simple minded as i am, if your singer ce100 works the stitch looks good just be glad you are not having the problems so many are, if you want to see bobbin thread on bottom tighten top tension
Sep 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 301A stitch jam
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Singer 3116 Simple Logo
75 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
