Question about Video Game Consoles & Games
My wii remote sensor is not picking up and will not work
  • 68 Answers
The sensor bar is actually an IR LED illuminator. Take a look at it (with the Wii on) on the LCD viewscreen of a digital camera. You should see three LEDs working on each side of the bar. If you do not, check the plug and the wire. You can get a replacement at your local retailer for about $20.
Posted on Jul 22, 2008
Console not responding. have changed remote and sensor bar
This information comes directly from Nintendo's website. Hope this can be of help:
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Verify Sensitivity Setting dots:
Go to the Sensor Bar's sensitivity setting in the Wii menu.
  • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
  • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Jan 02, 2011 | Nintendo Wii Console
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Remotes not picking up anything
I would suggest replacing the senor bar, it is not that uncommon that one the the Infrared LED's in the sensor bar to have burned out or go bad.
I personally use the wireless sensor bar after my original senor bar went bad
May 05, 2009 | Nintendo Wii Console
Wii not working
when putting in a cd its saying cant read disk
Dec 26, 2008 | Nintendo Wii Console
Wii remote
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Aug 08, 2008 | Nintendo Wii Console
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
Wii sensor bar is acting up
wii snsor is very sensitive has it fell or had any cracks on it. play around woith remote more, maybe it will pick up the pointer, if not available online or in some stores.
Jan 11, 2008 | Nintendo Wii Console
Wii Remote
make sure the remote light is on and ur sensor is picking up the movements, chek batteries as well/
Dec 19, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
