Question about Vtech V.Smile TV Learning System
Vtech v smile console (not pocket)
I can't get the controllers to work. When one of the controllers is plugged into the front of the console the green light (on button the sun) will turn off and the controllers won't work, we have an art studio pad also and it doesn't work either. I was wondering if there was some cleaning that I could do?
Thanks, my children and I appreciate any help you can give us.
Sandei
  • Anonymous Jul 22, 2008
    I have the same problem. when I can get my mine to come on at all it goes off when I put a game in. I have two of these systems and have problems with both. I dont have my users manual so I really need help.
  • Anonymous Dec 03, 2008
    darn! no one has a solution?!
I seen many problems with these systems.
I'm an electronics engineer by trade.
Most problems are due to the cheap plateing on the cartridges contacts..it can make the console do very strange things.
firstly push back the spring loaded cover for the cartridge contacts (on the cart' not the machine) and give em a dry scrub with a scouring pad and a good wiping with a dry clean cloth....works 90% of the time.
some times it is needed to strip the console and clean the internal contacts in the cart' slot.
Posted on Jan 13, 2009
  • 4 Answers
I bought a used one on Ebay. We couldn't get it to turn on at first. Then we got it to turn on when there was no cartridge in it, but when we'd put a cartridge in, it would turn off. I finally went online and found the manual. It suggested hitting the reset button on the bottom of the system. It's a small hole that you have to put a pin or something in to reset the system. It worked right away then. We started it up without the cart in there and turned it on, then put in the game. It kind of seems to be a picky system.
We are still having problems getting the Art Studio to work though. It seems like the system can't see the art pad.
Posted on Nov 26, 2008
  • 38 Answers
You might need to use batteries but if not it is probably a problem with controller going into the slot. is the slot for the controller a usb by any chance?
Posted on Jul 31, 2008
My daughter was playing her vsmile one morning and it work fine. But by the afternoon I can't get the controller to work. The system is working but you can't move with the controller. Any help? Thanks.
Posted on Nov 18, 2008
I have a problem that my son was playing with the v smile and all of a sudden turned off and doesn't want to turn on does anyboy had this same problem?
Posted on Sep 22, 2008
  • 3 Answers
I have the same issue with two of these units, and I find that leaving the power cable unplugged, plug the cart in, then plug the power in, sometimes it works. Sometimes you have to repeat this many times before it starts working. I am guessing it is a problem with the little card slot inside the unit, but not sure. Would be nice to have a better fix for this.
Posted on Aug 14, 2008
V tech pocket smile
Hi i'm Ryan, my daughters did the same thing, I removed the battery cover and there is a small pin hole with a reset button in it, try resetting it. I did and it came back on and works fine.
Dec 29, 2008 | Vtech V.Smile Pocket
I require a new power lead that plugs into back of console
You can get the adapter directly from VTech, or from Amazon, eBay, eToys, Toys R Us - they all have them.
Dec 16, 2008 | Vtech V.Smile TV Learning System
Turning vsmile pocket on with batteries
All you need are 4 AA battery of anykind. Open the back cover, remove the Vtech rechargable battery pack and insert 4 AA batteries in its place. Now your child will enjoy there Vsmile again.
Dec 14, 2008 | Vtech V.Smile Pocket
My daughter v smile pocket does not work
Sounds like the contacts on the games need to be cleaned. On the game cartridge, push back the little cover and clean the gold colored contacts on both sides. I use a cotton ball or q-tip with alcohol on it. Let it dry before you put it back in the v.smile.
Dec 09, 2008 | Vtech V.Smile Pocket Pink Electronic...
V tech v smile games
clean the metal with rubbing alcohol
Nov 22, 2008 | Vtech V.Smile Pocket
V smile pocket
Get an adult male to check jack and see if something was jammed inside, next open it up with screwdriver to see if anything is loose or contact manufacturer since warranty is usually a yr.
Nov 07, 2008 | Vtech V.Smile Pocket
V smile pocket problems
Do you still have your receipt? You could try to echange it at the store. Vsmile is coming out with a newer slightly different handheld model you could try. Though, we have a vsmile for the home and a leapster as a handheld game. Which both of my children have loved. Have you tried calling Vtech about the problem? I've had to call before about the home unit and they were very helpful. (Incedently, I have had problems with that, so if you ever do here's a helpful tip: Reset the machine by unplugging EVERY cord and pressing the two front buttons together for one full timed minute! We were having problems with a power issue and this solved it) They may be just as helpful as Leapster's Leap Frog company and send you a replacement! Once on a long car trip my daughter got sick in the car, while playing, so needless to say the game system got it too. And when I called Vtech about what to do, they sent a replacement! Try calling Vtech and see. You never know! Good luck!! :)
Sep 05, 2008 | Vtech V.Smile Pocket
Vtech V.Smile TV Learning System Logo
959 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
