Question about LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White
Water accumulates inside the washer
I recently bought this washer in Home Depot. i have only used it about 5 times when one morning i open the machine and found water inside (2 full buckets of it to be exact!!!!) after i drained it, the water looked dirty and smelled bad. i washed two loads and after i found a little bit of water after a few hours. there was nothing in the filter on both times.
    President:
  • 1,462 Answers
I guess you have washer drain pipe plumbed into a spigot on the sink trap. if so, when you empty sink, some of the water goes down the washer drain pipe and ends up filling your machine.
to cure, take the drain pipe as high up as possible under the sink in a swan neck and that should cure it. its a common problem
Posted on Jul 22, 2008
Automatic ice machine is producing brown ice
What is your water source and how does the water look from other areas, such as kitchen sink, toilet/shower? Did technician replace water line / tubing ? Lowe's and Home Depot carry tubing. Take off and replace. What has changed in your environment recently????
Cause and effect.
Mar 05, 2014 | Refrigerators
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
How do you clean a cold water inlet valve? Our city has had busted water lines and the silt has gotten into my lines.
unplug the washer, get at home depot "SILICON LUBRICANT", remove the fill hose, with a small screwdriver scrape the screen of the water valve and spray the lubricant to remove silt. repeat the proccess as needed. do the same at the faucet side. get new screens at home depot too. connect the fill hose at the faucet and take out the drain hose. put the other side at the drain and open the faucet to purge any dirt-silt for 2 to 5 minutes. install new screens at faucet side but not at valve side(valve has one already). open faucet and test wash. good luck to you.
Feb 07, 2011 | Washing Machines
Washer slowly fills with water when not in use. I
I have the same problem. The only problem that I have is not knowing how much water will eventually go into the tub. It takes about 4 or 5 days to accumulate about a gallon. I called the Whirlpool service center and the woman said they recomend turning the water off after each use-I think this is ridiculous. If going away on vaca maybe. Rob
May 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water accumulated in drum while machine off and door open.
The water valve may not have closed completely or may be leaking. You can copy and paste this link in your address bar for more great repair info and feel free to ask any other quesitons:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
LG washing machine has AWFUL mildew smell
have you tryed a boil wash with nothing in the washer to soften and expel any caked powder in the drum?i know this does help
May 27, 2009 | LG WM-2277HW Front Load Washer
LG Washer (Mod# WM2016CW) obvious mildew smell inside
Unfortunately this problem can occur with all front loaders made by any manufacturer. The problem results from excessive soap and body oils that do not fully dissolve and/or rinse clean from inside the inner and out tubs. Front loaders are energy efficient and only use a little water so any build up between the tubs that gets higher than the water level is left behind. It is also natural that some moisture collects between the folds of the door gasket and, if not wiped out, will mildew over time.
Not to worry, a few changes in use (as compared to top load washers) can easily eliminate your current problem and keep it from returning.
First of all, make sure to ONLY use HE (high efficiency) detergent and make sure to use no more than 2-3 tablespoons per load (because too much detergent will cause oversudsing, not break down efficiently and build up between the inner and outer tubs).
To eliminate the problem you now have I highly recommend a product called Whirlout (available at Home Depot in the hot tubs section). Just one capful in an empty load with the hottest water cylce will break down the current build up and take care of any odors (a 2nd cycle if the problem is really bad).
To avoid any problems in the future, use the correct amount and type of HE detergent, wipe the door gasket dry when done with the laundry (for the day, week or however you do your laundry) and run an empty cycle once a month with a capful of Whirlout. If your machine is in a high humidity location (i.e. a basement), then leave the washer door cracked open when not in use.
Hope this helps, please rate my answer.
Jan 05, 2009 | LG WM-2277HW Front Load Washer
Same here. We bought ours January 2005. Love the machines and take great care of them, too. Then the smell in the washer which seemed to affect certain clothes, like thick sweat pants and t-shirts (they smelled really "sour"). After doing some searches I found on this site where someone had recommended using a product called Affresh. I figured I might as well try it since my other attempts failed. This really worked for me. I bought it at Home Depot for $7 for a pkg of 3. I used 3 tablets per their directions, as this was my first time using it (afterwards they recommend using only 1 tablet per month). I was totally amazed as the smell was gone. I hope it works for you, too!
Oct 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Gasoline smell in the washer
White vinegar is NEVER a bad choice and I would use that.. start a wash ( without clothes) and when the washer fills with water.. stop it and open the door... add a cup or two of white vinegar and let it cycle thru ..When completed, leave the door open to allow the inside to air out... You can also use a product sold at Home Depot and other home improvement places called AFRESH ... hope that helps...
Sep 20, 2008 | LG WM-2277HW Front Load Washer
LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White Logo
140 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
