Question about Canon Office Equipment & Supplies
Scanning slides how to - Canon Office Equipment & Supplies
Idid not st the soft ware up correctly.THANKS
Posted on Jul 25, 2008
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help?
If not, let me know and we can investigate further.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
How to scan a slide on flatbed scanner
This model Canon MX700 cannot scan slides.
A flat bed scanner that can scan slides and negatives has a light scource that shines through the slide and negative fand is detected by the scanner sensor.
I suggest you purchase a slide scanner, it will be cheaper that getting a new flat bed scanner with slide capability.
May 17, 2012 | Canon PIXMA MX700 All-In-One InkJet...
Can I scan slides with Canoscan LiDE600F
Yep, The Canoscan LiDE600F is capable of scanning slides, however it is not possible to scan them in their mounts. If you dismount the slide, you can scan them using the film strip holder. This is not an elegant solution and you would have to remount your slides to use them as originally intended.
May 05, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
Dec 22, 2008 | HP Scanjet 4850
Cant scan 4cm x 4xm slides
The mounted slide scanning option is set for scanning 35mm mounted slides (24mm x 36mm). As far as I know there is no way to change this setting. You may want to try using the film scan option, do a preview scan, and then crop each individual slide for the final scan.
Oct 16, 2008 | Canon MP970 Photo All-In-One InkJet...
Scanning 35 mm slides
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scanning slides with anoscan 4200F
have you tried checking for a firmware update from the manufacturer?
Oct 13, 2007 | Canon CanoScan 4200F Flatbed Scanner
423 people viewed this question
old marine
old marine
