Question about JVC KD-S6060 CD Player
Peogeot 106 radio needs a code
I recently inherited a Peugeot 106 from my Grandmother and it needed a new clutch. Whilst having it repaired the radio must have been turned completely off as it now requires a four digit code. She didn't leave me the manual and I have no idea what it could be... does anyone have any sneaky tricks that might be of some use?
Thanks!
  • Anonymous Feb 14, 2009
    I have a similar problem. I had to replace the car's battery and in the process the radio locked itself. I was given the radio code 4325 with the car manual when i bought it, however, this doesn't seem to work?!?!
  • JVC Master
  • 4,886 Answers
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Posted on Sep 20, 2009
    Problem Solver:
  • 16 Answers
Go to a main dealer, or pull the radio out and get a decent one instead
Posted on Jun 01, 2009
Peugeot 307 Siemens VDO radio code?
no don't waste your time you need to go to a peugeot or citroen dealer have plug in in a drag and they will initiate your radio
your beep is ever 5/ to 10 second right?
Nov 09, 2014 | Peugeot 307 Cars & Trucks
Hi, need radio code for Peugeot 106 CL040130856774 PU-2294A(C). wonder if anyone can help please!
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
Aug 24, 2012 | Philips Car Audio & Video
Need to unlock my Peugeot 106 radio. Can someone help please? Model - 22RC200/65. Prod - FD1001109282133 PHAPKF19282133 TON461 029018. PHK92821333. Thank you !
When you disconnect your battery and then reconnect it again,it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Peugeot servicecentre and get them to enter this code for you.
Apr 09, 2012 | Car Audio & Video
Hi I have a peugeot. 106 an the stereo is askin for a code model PU-2294A (c) serial no is cl0401y0286760 please help!!
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
Mar 19, 2012 | Car Audio & Video
Hi, I changed battery for peugeot 106 zest 2 y reg and radio stopped working. and I need code.
remove the radio and check the casing for the radio code. Most dealers fail to remove the sticker identifying the radio with the car when in stock. Failing this you will have to take the car to a Peugeot dealer where they will retrieve it from their database. Hope this helps...
Mar 04, 2011 | Car Audio & Video
Hi I have a peugeot 106 and I need the stereo code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Radio Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jan 30, 2010 | Car APS95BT2 2-Button Code Learning...
Radio code required for old peugeot 106
youll probably have to contact peugeot directly with vin# and theyll be able to verify a code for you , but expect to give other info to i.d. you as the owner of said vehicle and equiptment
Jan 17, 2010 | Car Audio & Video
Need radio code for my stereo out of peugeot 106 numbers on it are pu-2294ac cl04011 064 0843
This code is only available from your Main Peugeot Dealer or a Decoding Company
Nov 25, 2009 | Vehicle Parts & Accessories
I have just purchased peugeot 106 Zest 2 51plate, I found clutch is stiff, my daughter is finding it very hard to push clutch.Please advise, if this is normal, if can it be Repaired
It can be repaired. From what you have told me it coud be the clutch cable. At the worse it will be a new clutch. I hope you find this information helpful.
Aug 24, 2008 | Peugeot 405 Cars & Trucks
JVC KD-S6060 CD Player Logo
240 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
