Question about Philips Televison & Video
I recently bought a Philips hts8100/37 for my parents,when I attempt to power it up to configure. I got a "entering low power" message & the glass door won't open. I changed the pwr source from a surge protector to plug it strsight into wall, no difference! help!
  • 4 more comments
  • oreshelman Jul 22, 2008
    Need to clarify; this unit is not a TV set,it a DVD Home Theater "soundbar" w/DVD Player.
    X changing the unit is tough since its fully installed w/all cables hidden in walls already,"they" seem unwilling to let me Xchange head unit only.
    As I said,I stupidly fished the cables thru walls,etc. already & would like an "in place" solution or Xchange/repair the head unit only.
    I followed pg 9 instructions numerous w/out any change.
    If I unplug it,as suggstd,for 5+ min & then replug it shows dull red light far rght corner,then as soon as I press pwr for a sec or 2 in order to turn - all I get is low pwr messg.
    Short of tearing all out of the wall,I've unplug every cable & connection,even "bypassing prev install cables w/substitutes outside w/out effect!
  • 2,427 Answers
Check if you unit has a power selector switch , ensure its set to your corrcect voltage , 110, or 220. also check your breaker or line supports the correct voltage amount or isnt shorting or loosing resistance
Posted on Jul 22, 2008
  • 97 Answers
Low power is just another word for standby, when doing this press the power on button again, or press something on the unit to power it up. if it still does not work you might have a power issue on the power board. call your manufacturer or ceck your manual.
  • 2,071 Answers
Try to use AVR automatic voltage regulator; due to the message quote; low power" message &
hope this may help;
    Genius:
  • 1,665 Answers
Power supply may be faulty. A service manual is necessary to troubleshoot it or if is not available, better take to an authorized electronics service station.
  • 4,234 Answers
There are a number of internal sensor circuits designed to protect the unit from major damage. It could be that one of these circuits is failing and "detecting" a problem that doesn't exist. In any case, this unit is under warranty. I would suggest that you return it for an exchange. Don't spend a lot of time on this, the unit is defective.
Dan
  • ABRsvcs Jul 22, 2008
    The "low power" standby mode is also an indication of protection mode. The user can force a "low power" standby as indicated by Ginko, the problem here is that the unit enters this mode automatically. This is because there is a problem with the unit. Try disconnecting the speaker wires only. Is there any change to the behavior? If so, look for a shorted speaker wire. The fault may be in the wiring inside the walls.
    Dan
  • Philips Master
  • 19,396 Answers
Check that you bought an appliance with same power specification required for your country.
For example if you are in UK it is 240Volts etc.
  • 3 more comments
  • Ginko
    Ginko Jul 22, 2008
    Check the sticker at the back of the appliance to find out required voltage.
  • Ginko
    Ginko Jul 22, 2008
    Hey "Low power " in your unit it is not an error message!
    It is just indicating it enters in the "low power standby mode" This is normal, just press the power on button to restart the unit.
    Your unit is fine, check low power standby mode in the user guide, it is just a standard feature.
  • Ginko
    Ginko Jul 22, 2008
    |Here is the manual,
    check page 9 it says:
    STANDBY ON 2
    – Turns on this unit or turns off to normal
    standby mode.
    – Press and hold to turn off to low power
    standby mode.
  • Ginko
    Ginko Jul 22, 2008
    You do not need to Xchange the unit, as the low power message is normal. Unit is just in standby mode, you need to turn it on.
    If you tell us where you did buy the unit from, I can get you in touch with customer support.
    If you damaged or modified the unit no replacement will be possible.
  • Ginko
    Ginko Jul 22, 2008
    Press the on button.
  • 813 Answers
See the manual
Philips 50" Plasma with ambilight
It sounds that there is some loose contacts to some connections to your Plasma display. Almost all plasma displays will have similar configurations to display circuits, will change only with the size of the screen. If you wish to get some details http://electronicshelponline.blogspot.com/ Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I haven't had a recent hardware or software change but when I turn on my Dell Inspiron 1521 laptop I get a black screen with the following message: Windows Boot Manager Windows failed to start. A...
boot from an applicable boot disk & use fixmbr to repair the boot sector,
OR have you tried safe mode or last good....( you need to press F8 seconds after the PC is turned on)
Dec 31, 2010 | Dell Inspiron 1521 Notebook
I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 05, 2010 | Philips MS2730C 27" TV
How to configure the router cisco with all parameters
3. Configuring your Cisco Router If you have just turned on the router, it will be completely unconfigured. If it is already configured, you may want to view its current configuration. Even if it has not been previously configured, you should familiarize yourself with the show commands before beginning to configure the router. Enter privileged mode by issuing the command enable, then issue several show commands to see what they display. Remember, the command show ? will display all the showcommands aavailable in the current mode. Definately try out the following commands:
Router#show interfaces
Router#show ip protocols
Router#show ip route
Router#show ip arp When you enter privileged mode by using the command enable, you are in the top-level mode of privileged mode, also known in this document as "parent mode." It is in this top-level or parent mode that you can display most of the information about the router. As you now know, you do this with the show commands. Here you can learn the configuration of interfaces and whether they are up or down. You can display what IP protocols are in use, such as dynamic routing protocols. You can view the route and ARP tables, and these are just a few of the more important options.
As you configure the router, you will enter various sub-modes to set options, then return to the parent mode to display the results of your commands. You also return to the parent mode to enter other sub-modes. To return to the parent mode, you hit ctrl-z. This puts any commands you have just issued into affect, and returns you to parent mode.
Mar 31, 2009 | 3Com Computers & Internet
Can,t remember parential block code
In the setup part for parental control, when it asks for the password..enter 0711 ( twice ) it will probably say incorrect password after the first attempt, do it again....This is the default code and sequence for Philips/Magnavox in 90% of there sets. Let me know and good luck.
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Lexmark E352dn printer. The screen showed that the Photoconductor needed replacing which I have done. However the screen still shows " 84 Replace Photoconductor " I have removed and...
the problem is that you need to reset the counter of the photoconductor unit. From the official site of lexmark, i find this solution.
Step Action 1 Enter the printer's Configuration menu:
  1. Power off the printer.
  2. On the printer's operator panel, press and hold the select button (pattlnk_11202006_2142-select_button.jpg) and the back button (pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif).
  3. Power the printer back on while keeping both these buttons held down.
  4. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons.
  5. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen.
2 Press the right arrow button (pattlnk_4122007_1837-right_arrow.jpg) until you see Reset PC Cnt. Press pattlnk_11202006_2142-select_button.jpg once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg again.
The printer will display a Resetting PC Count Value message and go back to the previous screen.
3 Press pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif once. 4 Press pattlnk_4122007_191-left_arrow.jpg or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
If the counter has been reset correctly, the printer should return to a Ready prompt.
5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that:
  • The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer.
  • The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer.
If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information.
Dec 02, 2008 | Lexmark Office Equipment & Supplies
Sungale dvd2026
i was just looking into updating the software on the pvr at philips.com. While reading the instructions, it mentioned that updating the software version would require me to go thru configuration again. This may include the parental code. Worth a try.
Nov 05, 2007 | Philips DVDR725 DVD Player/HDD Recorder
New Used tv
Yes there is my friend! Follow these instructions and it will work for you! Philips and Magnavox: Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jun 21, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
639 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
