Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Convergence goes away
We have fixed this set several times. We used the Sanyo chips but when we unplug the set the convergence goes away. What are we missing?
  • 1 more comment
  • rlamkin
    rlamkin Aug 30, 2008
    Problem was a lack of skill or knowledge by the tech. He did not write the convergence changes before he unplugged the set.
  • rlamkin
    rlamkin Sep 13, 2008
    Super - solved the problem.
  • rlamkin
  • 934 Answers
Saving the convergence settings to memory...
Posted on Sep 13, 2008
Picture convexs and goes 3d
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Televison & Video
Color alignment
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Mar 29, 2009 | JVC AV-48WP30 48" Rear Projection...
How can I go to convergence adjustment mode of Sony KP-EF41SNS , thanks
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse. If however your TV does not have a convergence problem those tips may help.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 01, 2009 | Sony KP-53HS30 53" Rear Projection...
Can an amature replace a convergence board?
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
Jan 24, 2009 | Hitachi 46F510 46" Projection HDTV
Convergence problem?
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 14, 2009 | Sony KP-65WS510 65" Rear Projection...
Arched screen
Screen looks 3D
>>>Solution<<<<
Jan 08, 2009 | Sony KP-51WS510 51" Rear Projection...
The red on the digital array will not line up.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Dec 07, 2008 | Hitachi 50DX20B 50" Rear Projection...
PHILIPS MODEL # 46PP93 0217 40 INCH.
It may be the fluid in the CRT or the convergence chips are bad.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 22, 2008 | Philips 51PP9100D 51 in. Television
I cannot get the convergence alignment on my Sony projection TV model number kp-51ws510
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Its a fairly easy fix.
Aug 01, 2008 | Sony KP-46WT500 46" Rear Projection...
Hitachi Mo# 53uwx10ba double image
Solution:
  • Screen looks 3D
  • Screen is bowed in or warped.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
