SOURCE: pc connected to th42phd7 but no picture, input button doesn't
are you on the right input. To use this set as a monitor you do have to change some settings in the options part of you tv. Also you need to make sure the set is on the right resolution for the PC. check you video options on the PC, and make sure they are the same on the TV set. Also you will not get sound from this type of cable..good luck
SOURCE: I have a Panasonic Viera tx l37g20b and i am
Just select the input button on the set, or the remote until the input your on is selected.
You should have a SOURCE select button on the remote control to select the input source. This should allow you to select the VGA input as the input source. You will also need to make sure your laptop is configured to output a signal via the external VGA port.
