Question about Acer X221WSD Monitor
Lines on the Screen
When I plug in my XPS 1530 into my acer x221w external monitor there are lines white lines scrolling through the screen. When I unplug the power cord of my laptop, the lines go away.
  • 1 more comment
  • neetfreek Jul 22, 2008
    I have already had the motherboard replaced by Dell. The guy said that maybe there is interfierence. So today I plugged a power surge and an extension cord downstairs, and I plugged another one in upstairs for the AC power supply for the laptop. I then plugged them in (Monitor and Laptop) and they were practically still the same.
    i've tried this monitor successfully on 3-4 other computers.
    i tried all of them, and they all have lines.
  • 558 Answers
2 possibilities video card is damaged and bleeding ac power from the motherboard or the motherboard is damaged from a power spike and is bleeding ac power into the video card(this would be my best guess based on yur description). that is the best i can do on this info you have given I recommend you take it in to a service center for a definitive answer.
Posted on Jul 22, 2008
  • 1 more comment
  • Scott Hill
    Scott Hill Jul 22, 2008
    that is good info to have it is the monitor cable with the issue i would say the grounding pin may be damaged or you may need to look and see if the pins are all there on th vga connector. but based on your new info it is the monitor or its cable, try taking the laptop into a service center and just try a different monitor and see if the same issue occurs ( you could say your looking for another monitor for the laptop and want to make sure its compatible). hope this help to solve the issue.
    http://www.acl.co.uk/pinouts.htm
  • Scott Hill
    try changing the monitor refresh rate down to 60 hz it is in the advanced section of the display settings. right click on the desk top select properties then settings then advanced then monitors then look at the refresh rate it should be set to 60 if not change it and see if that helps, if it is at 60 try changing it to 70 or 75 and see what you get.
  • Scott Hill
    This is a dell issue there is nothing else I can tell you to try to fix this issue, sorry.
Vertical gray lines
If you can obtain a desktop monitor used for PCs, plug it into the side port on the laptop. Start up the system and see if it runs OK on the external monitor. If so, the problem is with the LCD display on the laptop.
Feb 27, 2014 | Acer Aspire Computers & Internet
Z 5600 Acer will not power up get lines across screen or white screen or black screen and no booting up
Try plugging in an external monitor. Then reboot. That will answer your first question - "Is my monitor fried?"
Oh wait, the Acer Z5600 is an all-in-one. Does it have an external VGA port? Should have. Acer support is here: http://support.acer.com/product/default.aspx?modelId=1243
User guide here:
http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/AS_G_En_V09A1.pdf
Oct 24, 2012 | Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
The left side of my laptop screen wet all white with red green yellow blue lines running veretical lines running through it. looks like someone spilled paint on it
Vertical lines are usually caused by 2 things, either your graphics card is going bad or your screen is going bad. How you check if it is your graphics card is by plugging it into an external monitor (if you have one).
If the lines still appear on the external monitor then you know its the graphics card going bad, which isn't probably worth fixing these days if you take into account how must laptop pricing has dropped.
I hope this helps.
Best of luck!!
Mar 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, My acer laptop screen gets color vertical lines and cant see anything else. sometime it works fine but after some time it gets lines again
HI There,
The easiest way to troubleshoot your problem is to connect your laptop to an external monitor. If the lines on the laptop screen don't appear on the monitor, then you know you need to replace your screen and screen inverter.
If the lines appear on the external monitor as well, then your video card on the motherboard of the laptop is failing and you'll need a new motherboard or want to consider a new laptop, depending on the repair cost.
Regards,
Marcus
Nov 10, 2010 | Acer Aspire 5580 Notebook
Broke screen acer laptop how do I display it on another monitor
Holding down the Fn key and pressing the F5 key will toggle through all the video presets. That includes just the internal monitor, the external monitor and both monitors.
Apr 23, 2010 | Acer Aspire One PC Notebook
I VE GOT ACER X221W HAD IT SINCE 1 YEAR .. MY
I have acer aspire the mouse will not work
Aug 19, 2009 | Acer X221WSD Monitor
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
My ibm thinkpad t60 lcd screen is acting strange, it works at times and then begins to breakup into white scrolling lines down the screen for a period of time , when i tap on the edges of the screen it...
Can you plug in an external monitor? If the problem persists on the external monitor it may be a hardware fault, heat problem or a driver issue. If the problem is only with the internal LCD then possibly the cable between the laptop and the LCD is faulty or the LCD is damaged somehow.
Tapping the edges to "fix" the issue does suggest ath hardware fault though.
Jul 01, 2008 | Computers & Internet
Acer X221WSD Monitor Logo
247 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
