Question about Friedrich CP12C10 Wall/Window Air Conditioner
A/C unit leaked out of front
I have a through wall unit, and all of a sudden we got a lot of water draining into the room from the front of the unit. The panel on the outside seems to be attached with some type of plastic plug which I cannot remove. Any tips on how to make sure the unit drains outside?
  • jswenson Jul 22, 2008
    It's a through wall unit. How do you pull it out?
  • 958 Answers
Pull out the unit and make sure the drainage is not clogged with slime and dirt. there is a drainage from the front to the rear. clean it before putting it back and tilt it a little bit towards the back too as you return i in place..
i hope i was able to fix your problem...
pls rate me..
tnx,
drcool
Posted on Jul 22, 2008
Heat controller model B-dmc24sb-1 leaking water in to room
This is normally due to the drain hosing being blocked. Find where the hose drains the water to, which is likely to be outside the house or into the drains, and check that the end is not blocked. If this is OK you will need to follow the hose back to the unit and find where the blockage is.
Jul 03, 2017 | Heat Controller Heating & Cooling
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
Why does our LG air conditioning unit leaks? It's inside our room and the dripping water is damaging our wooden floor.. Please help.. thanks!
The drain is stopped up or the unit is not tilted back enough to drain out the back. If the drain is stopped up sometimes you can blow it out with compressed air from the bottom of the front coil. If the unit is not tilted enough in the wall or window it cannot drain out of the proper drain hole in the back of the unit. Hope this helps you.
Apr 12, 2011 | LG Heating & Cooling
THE AIR CONDITIONER LEAKS WATER FROM THE FRONT OF THE UNIT.
Look for the drain line coming out of the unit typically in the bottom. Clear out this drain line with a vacuum or water hose. It should begin to drain and stop leaking.
If the leaking continues, you may have a cracked drain pan or severe drain blockage.
Jul 31, 2010 | LG Goldstar GWHD5000 wall/window Air...
Water leaking into room
Angle your unit so the back is lower than the front and the water will run out the drain hole on the bottom.
Sep 02, 2009 | GE Heating & Cooling
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
Leaking into room
the drain may be clogged or clean filter/coils
Aug 11, 2009 | Heating & Cooling
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Friedrich CP12C10 Wall/Window Air Conditioner Logo
320 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
