Question about Microwave Ovens
Keypad is shorted out - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 23, 2008
  • John Schnecker Oct 11, 2011
    Anyone out there who might have information on how I would go about repair a shoted out keypad on the GE microwave, model # HVM1540DNlWW
Model Psa1201rss01 key pad shorted msg. Does it need both the main control and keypad control panel?
The keypad must be replaced, it is shorted just as the message states.
Feb 15, 2017 | Microwave Ovens
How to get the 5E error off my display on my kenmore microwave
fix it.
SE Shorted key 1. Check if cable of keypad has been inserted into connector of main PCB. 2. Check for short between main PCB and connector or keypad and cable. 3. If there is not a problem with connector on main PCB and cable of keypad, replace the main PCB.
Jan 22, 2016 | Kenmore Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Keypad shorted may need service
You'll need to carefully removed the keypad assembly and look for moisture etc.
Nov 29, 2017 | GE JVM1740DM Microwave Oven
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
Model JES1451DN1BB Service May Be Needed Keypad Shorted
If the keypad is shorted it will need to be replaced, also! the control board should be checked.
Jun 28, 2012 | Microwave Ovens
Microwave keypad shorted
looks like your buying a board unfortunately not worth the repair get a new microwave boards cost way to much
Nov 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave beeping and says keypad short may need service
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
Jul 26, 2010 | GE JVM1850 1000 Watts Microwave Oven
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Sep 08, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
1,089 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
