Question about Philips DCP850/37
Philips DCP850/37 My dvd player will play sound from my SD card but not the videos I have recorded on my camera. The message is "video codec not supported". What is the problem?
  • jilly2 Jul 22, 2008
    No leads being used - I am simply taking the SD card out of my camera and putting it into my portable DVD player. (Philips DCP850/37) I can view stills OK but when I select a video, I can hear the audio but there is no picture, just the message "video codec not supported". Hope this makes sense and you can help!
  • 476 Answers
Do you have the correct leads for your camera to the dvd player ?
Some leads are special for that task only
Search yuor dvd player model for the spec sheet on the net and check out the leads too,
Let me know the out come ,
Maybe a upgradeable dvd player,ie,upgrade via sd card???
Whats your model and make and I'll have a look too
Thanks
Posted on Jul 22, 2008
My dvd player will nbotr play my sd card on screen
A codec is a digitized set of instructions inside the computer that allows the TV or player to decipher the signal coming in, if you don't have that codec you can't play the SD. Sorry you are out of luck here.
Mar 13, 2016 | Sylvania SDVD1332 13" Portable DVD Player
How can I record audio onto the SD card?
what is the model of the cam?
some cams only do video
depends what its saving the file as
may be your software that wont play the audio but plays the video ok
check the codec used to save the audio
Apr 26, 2015 | SWANN Home Security
My sd card has mp4 files that wont play i keep getting the message <video codec not supported> does anyone know how to solve this problem
You'll have to reencode the videos to a supported codec. There are literally dozens of mp4 codecs. Try redoing them using Xvid or Divx.
Jul 06, 2011 | Soundstream VIR-7870NRB Car Video Player
Computer wont play a video i recored with my camera on my sd card
I understand, if you are able to record on the SD card, make your computer to recognize it and lastly if you can transfer it successfully with no errors, we can make it to work by choosing an appropriate media player. I personally would recommend VLC player. Latest version of this software can be found in:
www.filehippo.com
Still if you are not able to open/run the media file. Let me know the type of file. I ll then according do a research and suggest a specific codec or a player that will support the file type.
File type can be found be right-clicking on the file and selecting Properties.
Jan 15, 2010 | Acer Extensa 5620 Notebook PC
Video OK but no audio when use SD card on photo frame COBY DP702
Audio is probably recorded with different codecs, one of which is unsupported by your frame.
Mar 23, 2017 | Coby DP-772 Digital Picture Frame
I recorded a video on my samsung sc-dc 164 camcorder and i used my SD memory card instead of the disc. when i try to play my video from the SD card recording it won't play but can only hear audio from my...
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
Jun 28, 2009 | Samsung SC-DC164 DVD Camcorder
Carnt watch videos on my gogear mp4 player
When in doubt, do what the message says.
You have to use the Philips (Arcsoft) Media Converter to convert/transfer videos. If the converter is not recognizing a specific video type - FLV, for instance - download a free program called Riva FLV Encoder and convert the videos to AVI format first. Then the Philips Media Converter will recognize them.
The Philips Media Converter is not capable of converting an entire DVD - you will have to acquire video editing software, and then break up the DVD files into 15-minute chunks, and then convert each chunk.
If you are getting a codec error, do a google search for free video codecs - they are out there. Windows Codec Pack and downloading the latest version of quicktime will give you most of these needed codecs.
This player is not capable of playing copyright-protected videos - so don't even bother with them.
Additional information is available both from Philips website and from Arcsoft's website.
-Tha Mp3 Doctor
Feb 26, 2009 | Philips GoGear Flash MP3 Player
Importing video from memory card
it;s a codec problem (audio and video ). Find out with what method and codec the camcorder works...
U can also try more video players until it works (if u dont know what codec u need )....
(u should install the drivers for the cam on the computer , it should contain the needed decoder .... )
Jan 21, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Only getting Sound no vision when playing video on the PC.
i had same problem.  just get out your cd pro with the driver and video codec on it that came with camera.  just open up the video codec only!  nothing else.  left click on codec folder.  wait for window to come up with  "continue anyway" and click once on that.  let it download.  about 10 sec.  then click on driver folder  restart and you are done.   do not use USB hub or it will cause problems and never load or remove the SD card when power is on camera or pc.  download your video files from camera with the USB cord only using  MASS STORAGE.  or you might lose and corrupt data.  if you need to burd to DVD, at highest quality no more than an hour.  or use 2 DVD's.  use a converter program like CUCUsoft to make your   .avi files a mpg2 file, but click on avi-dvd.  now you can burn and play in you dvd player on tv.   paul
Aug 09, 2007 | Samsung SC-X300L Camcorder
Video footage will not play on computer.
I used http://www.free-codecs.com/ to download a codec pack, specifically the 'XP codec pack' located at: http://www.free-codecs.com/download/XP_Codec_Pack.htm it solved the problem.
Feb 15, 2007 | Canon PowerShot S2 IS Digital Camera
Philips DCP850/37 Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
