Question about Miele Dryers
Condenser dryer keeps tripping the trip switch.
    President:
  • 1,462 Answers
This is often because water has got into the fan area and is being thrown up on the heater by the fan.
take heater cover off and dry off.
take condensor out. in the space at the back, you will find a hole where condensate runs into pump chamber. this hole maybe blocked.
otherwise, check operation of pump
Posted on Jul 22, 2008
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
Condensed dryer keeps tripping out my electric when I turn it on
Disconnect from mains. Remove rear panel and water will probably come out. This water is being flung by the fan onto the heater hence tripping the electric.
cause of water being here is a blockage in the condenser stopping flow into water chamber or possibly but unlikely, failure of the pump
Oct 11, 2014 | Hotpoint Aquarius WD640 Front Load...
My hot point condenser dryer keeps tripping the trip switch, have changed fuse but still not working
This would tend to indicate a problem with the temperature sensor not switching off the heatercircuit so it overheats and then trips. As soon as it cools down the machine will continue to work OK. This shouldbe a very quick and cheap repair.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 07, 2012 | Hotpoint Ultima Tc71n Condenser Dryer...
Owohotpoint 7kg aquarius condenser dryer keeps tripping the power when i switch it on have emptied and cleaned all filters water drawers
is it kicking the breaker if it is check to see what amp it is, if it is a 15 amp breaker you will need a 20amp breaker
Aug 24, 2010 | Dryers
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Condensing tumble dryer tripping main power switch , power getting to power switch on the machine and buzzing when pushed then tripping at mains. any ideas?
found that moisture is getting to the timer control and causing mains trip!!!!!! need to dry out timer control then all should be well , aided drying with hairdryer, design flaw will cause this on most is70c i think.
Dec 23, 2009 | Dryers
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
White Knight condenser dryer trips the electirc
Hi i bought my dryer 4 years ago and within three months i had a technician to it3 three times, it had the same problem as yours all my fuses were tripping in the fuse box. eventually after 4 visits, the technician said there was a tiny hole in the back of the dryer which was letting condensation through and was dripping onto the motor. he put a small piece of rubber in the hole to make a stopper and it hasn't done it since. seems like a common problem but unfortunately only very few technicians seem to know how to solve the problem, thankfully it was still under guarantee at the time so got repaired, hope this helps and good look!!
Andrea
Dec 25, 2008 | Dryers
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
384 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
