Question about Siemens Dishwashers
Dishwasher takes too long
The washing cycle takes too long about 4 hrs to complete .water is not draining properly
    Problem Solver:
  • 10 Answers
First thing to check is the connection from the drain hose to the spigot under the sink. in most cases food accumulates there because the hole inside the spigot in not drilled all the way around when the d/w is installed and a "lip" is left where the food stacks onto. if clear check for a kink in the drain hose at the back of the d/w and all the way to the sink. if ok then time to check the drain pump.
take care.
Posted on Jul 22, 2008
I have a Bosch SHE55C05UC dishwasher and it just started to not wash properly and leave water in the pan below (first time it did not drain at all.. I tried the rinse/hold cycle and got the unit to drain...
I am assuming you have checked the filter and drain sump and there are no obstructions. Have you tried taking the drain pipe out of the sink downpipe and checking if it drains directly into the sink?
I am also assuming the wash cycle is completed when you open the dishwasher.
Do you hear the drain pump running?
Post your comment after you have checked the things I mentioned.
Jun 17, 2010 | Bosch SHE55C05UC Dishwasher
We have a Jenn-Air dishwasher. The water does not fully drain when washing cycle is complete. Roughly 1/2 to 3/4 inch of water remains. Any suggestions are appreciated.
Check the that the drain hose is not kinked in any way under the counter and leading to the garbage disposal. Also check that the port in the garbage disposal is not partially restricted, or that the kitchen drain is not slower than normal.
I had the slow drain issue recently, and it would take the dishwasher forever to complete a cycle.
Dec 17, 2009 | Kitchen Ranges
Won't drain completely after a cycle is completed
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Aug 31, 2009 | Whirlpool Dishwashers
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dish washer
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
May 14, 2008 | EuroTech EWF150 Front Load Washer
Hobart SR24C-4 Dishwasher can't drain completely
If this is a new occurance, and not "since it was installed", it may be the drain impellor. Little fins on top of the impellor sometimes get worn off. It is under the lower wash arm in the pump housing. The only trick to taking the pump apart is not loosing any of the shims.
Go to page 12.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/860F7951C087BD7F85256D36004978EA/$File/F43078.pdf
Also, (and most likely if the unit looses water during the wash cycle), any obstruction to the drain valve can cause it to not drain proper. The drain valve uses a little flapper valve to drain the unit. It has a rubber stopper that needs to properly close. The drain valve is at the front of the unit with a red coil and white plastic body. It needs to be closely inspected. (page 22)
If this is a problem since it has been installed, it is likely due to the running of the external drain line. (Too high)
May 10, 2008 | Hobart SR24C-4 Dishwasher
Dishwashers Logo
618 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
