Question about Nokia 6600
Four Keys of my Nokia 6680 are not working
Following keys are not working for NOKIA 6680
1. OPTIONS and BACK key
2. RIGHT and LEFT key of JOYSTICK
thanks in advance
  • DaniMalik Jul 22, 2008
    Thank you Brother!
    Master:
  • 382 Answers
Try to replace your keypad with a new one and check, if it fails take your mobile to a service centre for service..also Dont forget to claim warranty..Thank you!..
Posted on Jul 22, 2008
Tip
Sony Ericsson's secret menu!!!
To enter secret menu press following keys:
> means press joystick or arrow keys to right
< means press joystick or arrow keys to left
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus: < * * <
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language, then it may be difficult to switch to default language.
The shortcut is very simple. Just press < 0000 >
< stands for left arrow button or joystick and > stands for right arrow button or joystick.
on Jul 15, 2010 | Cell Phones
My nokia n97 fails to start and its diplay contact retailer plzzz help me out
Note: You may back up all your information on your phone before doing a hard reset
Steps to hard reset your Nokia N97:-
1. Switch off your phone.
2. Press left shift key (first key in the third row), the space bar key and the arrow key (last key in top row) simultaneously.
3. Keeping the above keys pressed, press the power key. Keep all four keys pressed till your phone asks for country details etc.
4. Now you may release the keys, fill in the details and you are done.
Apr 26, 2011 | Nokia N97 Cell Phone
How to format a Nokia 6680 cellular phone
the code is 12345 or 00000
OR:
for soft format dial *#7780# or *#7370# which restores the factory settinngs
but if you format the whole phone memory then follow the procedure below ( remember one things this will deletes all your mesages, all contacts, photos, notes etc in the phone memory.. your phone is like a new phone
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
thank you
Thanks
Jan 24, 2011 | Nokia 6680 Cellular Phone
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
When people ring me i can hear them but they can't hear me. Also if I record a sound I can't hear that either.
It may be mic problem in your mobile .
you can test whether mic is working or not with the help of menu that appear by pressing following keys
2. press *
4. press *
6. press *
you will get a service test menu in that select microphone option to test it
Jun 02, 2010 | Sony Ericsson W910i Cellular Phone
I forget my lock code in nokia n 71 and i can do nothing
the power on/off to
press and hold
After a few
will
Apr 17, 2010 | Nokia Unlock N70 N71 N72 N90 6630 6680...
How can i format a nokia 6680
if you want to format the phone turn off your phone press and hold the keys (( 3, * , and the answer key (( grean key )) and wail your holding them turn on the mobile you must keep pressing the 3 keys and when the phone is on dont remove your hand from the on botton so you have to keep your fingers on 4 keys and the phone will be formated
Jan 11, 2008 | Nokia N95 Cellular Phone
General: Memory full. Close some applications and try again
Do a Full phone formatting on your 6600! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card. Remove MMC
3. Switch-off your 6680 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680
phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory setting.
All apps. installed & not of the phones' default will be lost. If you did a backup on your MMC, you can restore it back to the C drive again.
Jan 11, 2008 | Nokia 6680 Cellular Phone
Reprogram my nokia 6680
Full phone formatting on a 6680!
If you encounter situation like below on your 6680,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6680! as steps below,
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680 phone.
Remember, do not let go all of the keys and hold keys until you see a Nokia turns to white and blink' and nokia logo!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip.
Dec 26, 2007 | Nokia 6680 Handheld
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
