Question about Nokia N95 Cellular Phone
N95 startup problem
N95 not booting up- just stuck on Nokia Screen flashing ive tried using the *+3+the green button combo but dosnt wk.
Plse help me
  • 1 more comment
  • billiebull Aug 02, 2008
    on the screen is got sim card not valid cant use the charger or usb lead locked to 3 uk
  • Anonymous Aug 05, 2008
    MY PHONE NOKIA N95 ALWAYS HAVING RESTART PROBLEM.....
  • Anonymous Nov 17, 2008
    Same problem here
  • 24 Answers
Do not consult a technicition i have had this problem and solved it for my friend, you were trying to update your n95 firmware using nokia software updater then it said please unplug and remove battery you should never touch a mobile during an update... anyway to fix it your n95 thinks its still in a middle of the update so charge your phone for 10 minutes (DONT TURN ON) then connect up to the computer via usb to your n95 then open up software updater and press start update it it says could not find deivce keep retrying it took me 20 minutes but could last up to 1 hour then it willl recognise the phone and continue update and turn itself back on only problem is that your phone will be reset but you still keep your memory card data
post back asap dale goodwin
Posted on Jul 24, 2008
N95 8gb botting problem,No display
Posted on May 19, 2009
Cant even get the charger to work do meen take it to a shop and get it looked at
Posted on Aug 02, 2008
    Genius:
  • 1,011 Answers
It can be the programming fault or lcd problem. check it to a tech.
Ive forgot my lock code for my n95 8gb, how can i reset it? also im from the uk. thanks
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Jun 24, 2010 | Nokia N95 Cellular Phone
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
Nokia N95 8G - freezes when you turn it on and you can't go past the NOKIA welcome screen. Tried taking the battery out, charging it, etc.
Just format your phone by the following way
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Sep 29, 2009 | Nokia N95 Cellular Phone
Keeps playing first few seconds of music files
Start by taking the battery out and reinstalling it.
If this doesn't work, and the keyboard is still responding, use the "soft reset" code - *#7370# - you will need to enter the phonecode (12345 if you have never changed it).
If that doesn't work, then use the "hard reset" code *#7870# - but be aware that this will delete all data that's stored in the phone memory - the contents of the memory card are not affected, however.
Finally, there is the phone reformat, which will also erase all the settings and data on your phone - to do this, remove the battery, reinstall it and hold down the "*", "3" and "Answer (green phone)" buttons and while holding them down press the power button. Hold the keys down until the phone starts asking the startup questions again. Having 3 hands helps for this proceedure.
If this doesn't help, then the last thing to try is to reinstall the phone firmware using the Nokia software update service - http://europe.nokia.com/get-support-and-software/download-software/device-software-update
If it still doesn't work after that, then about the only option is to take it to a Nokia service centre and get them to fix it, since it sounds like a hardware problem.
Aug 01, 2009 | Nokia N95 Cellular Phone
Nokia N95 is not starting up
Your phone has Start up failure problem. You have to flash your phone and then install new firmware of your phone. There is just software problem with your phone.
Jun 26, 2009 | Nokia N95 Cellular Phone
Problem with nokia n95 8gb
Oops this doesn't sound good. Try following (hard reset) : push and hold the green button and 3 button and while holding them push power button until it restarts. If this doesn't help then back to the shop for replacement.
May 13, 2009 | Nokia N95 Cellular Phone
How to reset my factory setting in my n95 phone? i forgot my pwd.
Hi
Be warned: backup any important data before attempting this with your phone
Press Call(green button) + 3 + * simultaneously during the bootup(startup) phase untill you see the first screen , forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Mar 30, 2009 | Nokia N70 Cellular Phone
Failed update with nokia updater
Your update must have failed , now you have to do a hard reset of your phone , you cannot do the normal #*7670# , so use the following
Press and hold Green ( call send button )
Also press the * ( the Star Key )
and number 3 and keep them held and power on your phone and keep the button pressed until Nokia screen comes on .
If this solution help please do vote for me
Jan 04, 2009 | Nokia N95 Cellular Phone
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
595 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
