Question about Minolta EP1030/1030F CS/PRO Copier
Minolta ep 1030
Paper jams c f 3 flashes
    Problem Solver:
  • 17 Answers
It is not actually a paper jam - when the copier detects a malfunction, it simply stops everything. Paper jams all have "J" codes (J1, J3, etc.).
A CF3 indicates a problem with the ATDC system (Automatic Toner Density Control). The output from the ATDC sensor is outside normal specs.
Possible causes would include the copier being run (and reset repeatedly) without toner, the imaging unit not being properly installed (or not present at all), use of toner not compatible with the unit, a defective ATDC sensor or (least likely) PWB-A.
Posted on Jul 23, 2008
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
My photo copier keeps saying pc ?
I worked on a EP 1030 copier and the error PC is when the machine doesn`t pickup paper. Make sure pickup roller is clean and there is paper in paper tray.
Mar 29, 2011 | Minolta EP1030/1030F CS/PRO Copier
Error code j3 for ep 1030
j3 - exit jam
search for a lever at the exit point of the copier, you sould be able to see the sensor at the lower part of the fuser. I may bejamed or the flag broken.
Nov 12, 2010 | Minolta EP1030/1030F CS/PRO Copier
Konica minolta EP-1031 PC code and toner install
PC MEANS NO PAPER IN THE TRAY OR PAPER JAM IN MACHINE WHEN TURNED ON. WHEN OUT OF TONER RED LIGHT SHAPED LIKE A PYRAMID WILL COME ON
Apr 16, 2010 | Office Equipment & Supplies
Minolta ep 1054 copier paper jams and 3 appear on the panel
you mean a J3? check the fuser section the hot part. replace the parts as required
Jan 03, 2010 | Minolta EP1030/1030F CS/PRO Copier
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
Paper jams and c f 3 flashes
CF3 - ATDC sensor malfuntion. This sensor measures the density between toner and developer. You might have a problem with too short developer. Add some more and do F8.
The manual says basically that you either have a problem with de sensor (under a bottom plastic plate of the image unit) or the main board (PWB-A).
Jul 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
467 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
