Question about IBM ThinkPad T23 Notebook
Battery/docking station ac power
I use a docking station, but somehow I'm currently just working off the battery. How do I change back?Sue
    Genius:
  • 2,028 Answers
There is no manual way to switch from battery to AC, the machine or docking station should automatically switch between battery and AC. There is a power management chip inside the laptop that regulates the power and switches from battery to AC when plugged in. Some docking stations have a chip built into them to do this. Start by ruling out the power supply. Do this by undocking the laptop and plug it in using the power supply that is attached to the docking station and see if the machine is just running off of battery. If it is running off battery, then check the power supply with an ohm meter for the proper output. The output readings are on the supply. If you have two power supplies, and you know one works with the machine, try that supply on the docking station. If the power supply checks good, then I'm afraid the pm chip on the motherboard has gone out. You will need to take this in to have it professionally diagnosed, because it could be a replaceable component that works in conjunction with the pm chip. However, if it is the pm chip, then the motherboard will have to be replaced in order to fix it.
Posted on Jul 22, 2008
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit www.kodak.com/go/z650accessories for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
My dell 620 battery will not charge with the power supply, yet it charges in the docking station. The laptop will run fine with the power supply except that the battery will not charge till I place the...
sounds like the situation is with the AC adapter detection. try to restore your BIOS defaults and update BIOS if applicable. Test another AC adapter. If that fails, most likely, this is with the motherboard. You may either get a new board, or just continue to charge it using the docking station.
Dec 31, 2010 | Dell Latitude D620 Notebook
E5500 will not turn on after disconnected from docking station
I just want to know, removing battery and docking station, and just use the ac adapter alone still no power on the laptop? If yes please replace the motherboard.
Mar 31, 2010 | Dell Latitude E5500 Laptop
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Lenovo T60 power port not working
If the docking station charging doesn't work either and your battery is ok you have lost voltage regulator (it prevents overcharging of battery) Take the battery to a battery plus store and they can check it..
Sep 10, 2009 | Lenovo Thinkpad T60 Notebook
Dell D610 only can run on battery, not accepting AC power or from my docking station. I check the PA-12 AC charger and is working fine with other D610. Please help.
If not powering from DOCK, AC adapter and only from battery, since the Battery, DOck and adapter are known good, it is a matter of a motherboard replacement
Jul 09, 2009 | Dell Latitude D600 Notebook
Power jack connection broken on HP Omnibook xe3
I bought a docking station (port replicator) off ebay, and it has worked great. I had a look at the motherboard, and the docking station uses a different connection for power than the damaged AC port. So in summary, yes a docking port should solve your problem.
If you can get a docking station for it you may be able to solve it that way.
Apr 15, 2009 | HP OmniBook XE3 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
DEAD PRESARIO 1925 NOTEBOOK
Try this, with laptop removed from docking unit:
1. Press and hold the laptop power button down, for 10 seconds.
2. Now remove the battery
3. Repeat step one above
4. Let the laptop sit for 10 minutes.
5. Reinstall the battery
6. Make sure docking station is unplugged, and insert laptop into docking station.
7. Plug in power supply (to dock)
8. Start the laptop.
9. IF IT STARTS, let it run a while to see if the battery is charging
10. Remove it from the dock and repeat steps 1-5 above and then go directly to 8 (start without connecting dock).
CONCLUSIONS: If the laptop started in the dock on step 9 but not 10 (only on battery), your battery or power regulator circuit may be damaged. However, if it starts in step 10 but not step 9, your docking station -or its AC power supply may be damaged Let me know how this comes out, please.
Jan 15, 2008 | Computers & Internet
IBM ThinkPad T23 Notebook Logo
151 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
