Question about Ricoh Aficio 2018D All-In-One Laser Printer
Error 36851: No response from scanner" ricoh
    Welcome Back:
    Visited the website for 2 consecutive days.
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Posted on Feb 07, 2012
  • Anees Mohyuddin
    Anees Mohyuddin Apr 04, 2013
    dear where i can find this menu
    New Friend:
I have been pulling my hair for three months trying to fix this. I installed McAfee and this is controlling my Windows Firewall. Disable the firewall long enough to scan what you need, then turn the firewall back on. This is the ONLY thing that worked. I am going to reset my firewall to allow Windows, not McAfee, to control the firewall settings. Hope this helps, it helped me.
Posted on Oct 13, 2014
    Guru:
  • 124 Answers
You have to just replace your cartridges.It show the error because the cartridge has a problem.
Posted on Feb 07, 2011
SOURCE:
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
I am trying to setup the 1515MF for network scanning. The manual tells me to go to scanner and select Twain on. But when I go to scanner features and then scan settings, my only choice is "default...
First download the twain drivers from Ricoh website or if you have cd down load it from it. Then from there when you go to scan should give you selection option for it.
Jan 05, 2018 | Ricoh Aficio 1515MF All-In-One Laser...
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
I can not use the scanner, Ricoh Aficio 1515. I alredy instal the twain driver ver.3 from the original cd, when I open the function palete, looks like its conected with the machine, but when I try to...
Visit the Ricoh download site and download the latest driver. This will ask you if you wish to overwrite, say yes. Hopefully this will replace the corrupt file.
Aug 01, 2008 | Ricoh Office Equipment & Supplies
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
16,577 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
